Question about Frigidaire FRS26H7CS Side by Side Refrigerator
Sounds like a freight train.
My refrigerator has always made a loud sound since the very first day it was installed. The sound is comparable to a freight train. Now, 5-1/2 years later, the refrigerator has completely stopped working. Is this the typical lifespan of a Frigidaire refrigerator?
SOURCE: Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Posted on Jan 10, 2009
  • 1214 Answers
SOURCE: frigidaire refrigerator model FRT21LRGW5-compressor sound is loud
Sounds like the start relay or start capacitor has failed.
Unplug the unit until you can get a replacement or the compressor will be ruined (if it's not already.).
PTC start relay is P/N 218721108 $36.49
Capacitor is P/N 218909901 $7.99
P/N and pricing from Sears Parts.
Posted on Feb 01, 2009
wheelshot
  • 102 Answers
SOURCE: a three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Posted on Apr 01, 2009
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
  • 122 Answers
SOURCE: 9-10 year old Frigidaire Gallery FRS26ZSH
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Posted on Jun 27, 2010
Loud noises in counter depth GE profile model pwe23kskess
refrigerators now a days have thinner cabinets & foam insulation, which resonates motor sounds . some high end refrigerators have added sound deadners which quiet the sounds somewhat.
Apr 27, 2018 | GE Refrigerators
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at appliancepartspros.com. You could also look atR44U61 RepairClinic.com
May 02, 2017 | Maytag Washing Machines
Hi y'all! I recently aquired set of Neptune W&D. Washer is a TL and has 2 problems: 1. When washer goes into the spin mode, it sounds like a freight train going by. VERY LOUD...like maybe the...
Them are junk...Lol sorry but yes in the back where the pulley is there is a bearing and you have to replace the whole thing a 500$ part
Mar 13, 2011 | Washing Machines
Final spin loud noise out of balance??
sounds like your bearing is shot
is this a fridgedair?
does it sound like a 747 or freight train?
if yes might as well throw it away
I would say your looking at about 5-6 hundred dollars to repair
you will need the basket and outer tub
the reason is your bearing is compressed from the factory in your outer tub and your basket shaft goes through the bearing
and usually gets eaten up by the bearing
Feb 11, 2010 | Kenmore 43142 Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Goodman ac condenser, Loud and wet
Over charged with refrigerant>
Sep 12, 2008 | Heating & Cooling
Maytag neptune MAH4000AWW Very loud noise when spinning
I found this on line ... 6/15/09 . Does your Maytag Neptune front loader sound like a runaway freight train when it is in high speed spin cycle? 2. Is your Neptune getting so loud that you cannot be in the same room while it is spinning your clothes? It sounds like your bearings may need some attention if you answered YES to the questions See www.neptunebearing.com ... Frank frankbusch@comcast.net
Sep 08, 2008 | Washing Machines
Mitsubishi big screen TV
Sounds like something in the deflection or audio circuits. Wish I could help more. I will post a link where you can get the service manual.
http://servicemanuals.vstore.ca/
Feb 28, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Frigidaire FRS26H7CS Side by Side Refrigerator Logo
150 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
