Question about Tools & Hardware - Others
I need to calibrate the coats 850 wheel balancer can u send me instruction on this
to calibrate coats 850, first you take a balanced wheel, tie it on machine shaft, enter the wheel dimension or wheel data such as distance, width and diameter, the press c90c, start the machine after completing cycle machine stops, add 100gm wieght out side the wheel and run it again, after this complete cycle your machine will be calibrate,
if you have any problem you can sent me email on zafakar@yahho.com
must reply me.
best regards
Zafar
bye
Posted on Oct 17, 2009
How do I calibrate a Coats 700 tire balancer?
go to google --type in nytechsupply.com and there is a full operatots manual for that machine
you tube states that it is an auto calibrated machine
there is a calibration check procedure in the operators manual and again it states that the calibration is to fine tune for single spin operations.
I found this by typing into google---calibrating a coats 700 tyre balancer and there are pages which included the nytecsupply page.
Feb 07, 2015 | Cars & Trucks
Electrical Board Wiring diagram for coats 850 balancer
This was all I could find:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC8QFjAA&url=http%3A%2F%2Fwww.nytechsupply.com%2Fdownloads%2Fwheel_balancer_operation_manual%2FCoats_850_Operation_Manual.pdf&ei=omHAUczML-fE0QHqooHACg&usg=AFQjCNEm9EqJ9mDHaXPRhXNbfvweNtaDaw&sig2=UrkSObN8BHVH-GWyVUG0ZQ
Jun 18, 2013 | Cars & Trucks
My coats 1050 tire balancer does not cycle, it wants to run wide open
Did you ever figure out what it was Brian?I have the same issue with my Coats machine.
Mar 24, 2012 | Cars & Trucks
Naki Touring Wheel - Model 57063
You can calibrate it in Windows by accessing Device manager and select you steering wheel and right click on it to got to properties / in there should be calibration.
OR it will be in the sterring wheel driver software.
Apr 09, 2010 | Naki TOURING WHEEL (57063)
Drum is very noisy even when spun by hand
The drum may be off balance because a support wheel or bearing is not operating correctly. A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 16, 2009 | Hotpoint WMA66 Front Load Washer
How to operate my 700ss wheel balancer? COATS/HENNESSY 8112700 700 WHEEL BALANCER 110V
the manual can be located athttp://partners.ammcoats.com/docman/viewDocument.asp?sParm=hemmfdmoc-t~e-t
Sep 24, 2009 | Tools & Hardware - Others
I have the exact same truck with the exact same problem.
send me the last 9 of the vin and i will find it for you
Sep 24, 2009 | 2007 Dodge Durango Night Runner New Cars
Steering Wheel shakes at 60+
IT HAS TO BE BALANCE if it was shocky related or loose wheel bearings it would have been in evidence before the tyre change ---I would recommend you take it to one of the better tyre only establishments and ask them to balance your 2 front wheels both inner and outer please let me know the result, imay learn something------------------------but I doubt it
Aug 14, 2009 | 2004 Jaguar X-Type
Tools & Hardware - Others Logo
2,979 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
