Mitsubishi VS 4502R. Convergence stinks. (Not the built in convergence. Can it be re converged or do I have to replace the board? If so how much should it cost for either? Can I do it myself?
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
If your colors do not line up at all on the screen this is most likely the problem, and it can be repaired by replacing the convergence IC’s. This can be done but it is not the easiest repair to tackle, as there is associated resistors and coils that can open when the IC’s fail.
I usually recommend that both, or all three be replaced (depending on your set) because if one is bad the others are most likely close to going out too.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair.
I have done this repair for around $300.00, but you can get the parts for around $120.00. I recommend the OEM parts, as you can find very cheap IC’s that look just like the originals, but they will not last long.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 13, 2009
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the partstore.com with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
My Mitsubishi vs-5061 isn't working properly. The red crosshair wont line up with the white ones going horizontally. The red is bowing. Causing most writting to have a double vision look. HELP!
Hi, this will occur when the convergence unit has failed . you will need to replace the convergence board in this unit in order to restore proper convergence functions. This is just below the optical assembly in the PCB main area next to the signal board and terminal block.
Jul 26, 2009 | Mitsubishi VS-50611 50" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50501A convergence problem
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
