Question about Samsung SCH-a950 Cellular Phone
Phone won't charge. when plugged into wall
Phone won't charge. when plugged into wall charger, it keeps restarting as if you just plugged it in approx. every :40 sec, but won't hold charge. bought new wall charger, but still have the same problem. also bought a new battery, no luck
    Sergeant:
  • 205 Answers
Your old battry boost for 6v charge 1 second try it now working or new samsung orginal battry use only other not working
Posted on Jul 13, 2009
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Screen cell phone keeps blacking out
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
May 23, 2013 | Pantech Ease P2020 AT&T
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Won't charge up
Hi, I am incliened to put the blame on the charger. Do you have the possibility to borrow use another charger? If you do, try it.
all the best
Kolbrun
Feb 17, 2012 | Nokia 6085 Cellular Phone
What's your problem? i phone lost nearly all charge, now not charging, how do i reset it
Plug your iPhone into the wall charger to charge. If you can see the lightning sign, plug the iphone into your pc then restart your computer. Apple logo should now come up and phone will boot as normal
Nov 04, 2011 | Apple iPhone Smartphone
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Sep 01, 2011 | HTC Hero Smartphone
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Phone switches off when charging using car charger
the phone appears to switch off when I plug it into my charger and restart again show only charging message havent a clue why,plz help me on this matter. thanks
Aug 21, 2008 | Motorola Mobility A1000
Phone keeps restarting while charging
Some chargers dont work with this particular model of phone even though they fit. One that works for me is called a I-GO you buy the tip separately from the cord and its a little bit expensive, roughly 40 dollars, but it works lol.
Jun 18, 2008 | Samsung SGH-A707 Cellular Phone
Samsung SCH-a950 Cellular Phone Logo
292 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
