Question about Vehicle Parts & Accessories
Car won't statr after cd player was installed
Car won't start after cd player was installed. the vehicle has electrical power but the starter will not turn. a cd player was installed and the original radio removed. something about the anti theft system. how can this be bypassed?
  • Anonymous Mar 31, 2014
    is this anything to do with the pass-key system or the theft-deterrent system that is factory installed. How do I dis-arm this feature?
  • 21 Answers
Dont know for sure try unhooking battery for 15-30 min
Posted on Jul 13, 2009
Won;t start nothing works except lights and beeping sound when door is open where is the starter located
Do you know how to do electrical testing ? Engine Won Start No Crank Diagnosis Troubleshooting Starting System Issues No Crank Troubleshooting engine does not crank The starter is under the vehicle bolted to the bottom of the engine ,most usually > Some car makers hide it under the intake manifold in what is referred to as the valley on V - engines . The way modern vehicles are the starting system is computer controlled . A relay is a switch controlled by the PCM - engine computer .
Nov 15, 2015 | 2008 Dodge Charger
Tip
Vehicle won't start when hot
A common problem that's surfaced a great deal lately is a car/truck that starts fine when the engine is cold but won't when the engine is warm. Most of the time, the car will require a jump start with a warm engine to get it to start. Most mistakenly assume a bad battery and change it out, only to have the same problem. What happens is most starters don't just "quit" when they are defective. A bad starter will usually start your vehicle when it's absolutely cold. Once warm, the starter will behave as follows:<br /> <ul> <li>No power</li> <li>Click then nothing</li> <li>All other electrical is fine (headlights, stereo, alarm etc)</li></ul> If your car or truck won't start when the engine is warm, but starts fine when it's cold, you most likely have a bad starter. Although replacing the battery is less expensive, it rarely (if ever) will resolve this issue. Consider the age of the car / starter when these symptoms occur. If you have an older vehicle (older than 5 years) then replacing the starter is a good place to start prior to buying other electrical components (battery, alternator). <br /> <br /> Always bring the vehicle to a shop that offers a free electrical diagnostic test to confirm the electrical system is sound to rule out an electrical problem first. If the electrical system is sound, I'd go ahead and replace the starter. <br />Although this tip will show under the Lincoln category, it applies to all makes and models.<br />
on Jun 16, 2011 | Lincoln Continental Cars & Trucks
I have a mazda millenia 01. I put a different cd player in my car. Cd playee would not play and engine light is on now. When i first start my car the gages go up, then back down.. lights on inside...
You apparently have a vehicle with the Anti-theft system on the Audio system. I would put the original player back in to avoid future problems! The vehicle will behave erratically while the replacement unit is installed!
Apr 27, 2012 | 2001 Mazda Millenia
Change starter wire on 92 eldorado
A starter motor problem won't cause the car to stop, You need to make sure that the earth leads from the battery to the body and to the motor are tight and that the surface they bolt to is clean, there could also be an issue with the electrical switch on the back of your ignition.
Mar 08, 2012 | 1992 Cadillac Eldorado
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
How to replace the starter on a 03 Ford Expedition?
SECTION 303-06: Starting System 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 11/06/2002 Starter Motor adobe.gif Printable View (188 KB) Removal
ani_caut.gif WARNING: When carrying out maintenance on the starting system be aware that heavy gauge leads are connected directly to the battery. Make sure protective caps are in place when maintenance is complete. Failure to follow these instructions may result in personal injury.
  1. Disconnect the battery ground cable.
  1. ani_caut.gif WARNING: The electrical power to the air suspension system must be shut off prior to hoisting, jacking or towing an air suspension vehicle. This can be accomplished by turning off the air suspension switch located in the RH kick panel area. Failure to do so may result in unexpected inflation or deflation of the air springs which may result in shifting of the vehicle during these operations.
    Raise and support the vehicle; refer to Section 100-02.
  1. Remove the starter motor solenoid terminal cover.
  1. Disconnect the starter motor electrical connections.
  1. Remove the starter motor.
    1. Remove the stud bolts.
    1. Remove the two bolts.
    1. Remove the starter.
Installation
  1. Install the starter motor.
    1. Position the starter.
    1. Install the two bolts.
    1. Install the stud bolt.
  1. Connect the starter motor electrical connections.
  1. Install the starter motor solenoid terminal cover.
  1. Lower the vehicle.
  1. NOTE: If equipped with air suspension, reactivate the system by turning on the air suspension switch.
    Connect the battery ground cable.
Mar 08, 2011 | 2003 Ford Expedition
How to remove and install starter motor on 2000 malibu location of mounting bolts
REMOVAL & INSTALLATION 2.4L Engine
  1. Disconnect the negative battery cable at the battery.
  2. Detach the air inlet duct from the throttle body.
  3. Position a drain pan under the oil filter, then remove the oil filter.
  4. Remove the top starter bolt.
  5. Raise and safely support the vehicle.
  6. Remove the lower starter retaining bolt.
  7. If necessary, position the engine wiring harness aside.
  8. Position the starter to enable access to the solenoid wiring, then detach the wiring.
  9. Remove the starter from the vehicle. To install:
  10. Raise the starter to the vehicle, then attach the wiring.
  11. Position the starter, then secure using the lower starter bolt. Tighten to 66 ft. lbs. (90 Nm). Fig. 1: When installing the starter on the 2.4L engine, tighten the mounting bolts to 66 ft. lbs. (90 Nm) 87952040.gif
  12. If moved, reposition the engine wiring harness.
  13. Attach the solenoid electrical connectors.
  14. Carefully lower the vehicle.
  15. Install the top starter bolt, then tighten to 66 ft. lbs. (90 Nm).
  16. Replace the oil filter.
  17. Fasten the air inlet duct to the throttle body.
  18. Connect the negative battery cable.
  19. Check the oil level and add if necessary.
  20. Start the engine, recheck the oil level and add if necessary.
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Raise and safely support the front of the vehicle securely on jackstands.
  3. Remove the lower closeout panel.
  4. Remove the electrical leads. Fig. 2: Two electrical leads connect to the starter solenoid. The larger one has battery power as long as the battery is connected. The smaller one only has power when the key is turned to START 93202p09.jpg
  5. Remove the starter motor to engine bolts, then remove the starter from the vehicle. To install:
  6. Install the starter. Position one engine-to-starter bolt in the lower bolt hole, then finger-start the bolt.
  7. Connect the electrical leads to the starter. Tighten the cable to the solenoid to 106 inch lbs. (12 Nm).
  8. Install the starter-to-engine bolts and tighten to 37 ft. lbs. (50 Nm)
  9. Install the lower closeout panel.
  10. Lower the vehicle.
  11. Connect the negative battery cable.
Jan 21, 2011 | 2001 Chevrolet Malibu
I have a jvc radio cd player the unit will not come on when ignition turned on. it just says hello goodby
This the typical behavior of any car radio/cd/dvdplayers. when the engine is cranked, itresponds by momentary supply of current and divert it the starter motor. it has to 'cos cranking any engine/started, it automatically stops any gadget which happens to be ON. have you evert tried to start the engine with the Head Lights already on?
This is perfectly normal for any vehicle with electric motor as the starter(self start).
hope that i've manged to explain why & its the defalt setting in all vehicles
Regards
sodeep
Oct 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
