Question about Lego Creator Revvin' Riders, Motorcycles and ATVs
Not charging need info to make sure it,s the charging coil
  • 160 Answers
If the bike starts and runs, but is not charging the battery, it's the coil. Otherwise check to the stator and voltage regulator/rectifier.
Posted on Jan 05, 2010
Help please!I need a 31510-ZE8-701 COIL ASSY., CHARGE (Honda Code 2171288) for a ride on mower HT-R3009 but this part seems to be obsolete any advice welcome. Many thanks
Tim, Try the link below for your coil, they may also give you an alternate part number. You could also contact Honda small engines for an alternate replacement part #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Honda COIL ASSY CHARGE
Honda Engines
Jul 18, 2016 | Garden
Replaced bad fuel pump. Still will not start. Only 6 volts at the pump relay. Bypassing the relay indicated pump is working and plenty of pressure. Checked all the fuses all are good. Any ideas?
Year make and model ?
You should have two hot circuits to the relay. One is for the pump and the other is for the coil of the relay. Usually power comes from the key switch.
Jan 01, 2016 | Cars & Trucks
I have a 15 seer American Standard Heat Pump and the air handler is leaking out of the cabinet instead of the drain pipe.
ONLY GUESS BUT ONE THING IS PAN CRACKED ON EVAP COIL OR IT COULD BE COND. TO MUCH WATER FROM LOW CHARGE OR DIRTY AIR FILTERS ONE WAY THAT IS EASY TO CK IS REMOVE COVE OFF AIR HANDLER TURN OFF UNIT AND ADD A LITTLE FOOD COLORING WITH A LITTLE IN PAN AND SEE IF YOU CAN SEE LEAK USING DYE , ALSO MAKE SURE PORT LEAVING PAN IS FOR SURE UNOBSTRUCTED****** IMPORTANT THEY CLOG RIGHT WHERE IT LEAVES UNIT OFTEN
Aug 18, 2014 | Heating & Cooling
P3ra-048k uses what type of refrigerant and manufacture charging chart
This sounds like a trick question. Are you a service man? You must know HVAC well if you know sub cooling! There is a tech info plate on the unit that tells you how much and what type of refrigerant. Check the fan direction and if indeed it is running at all. If its icing up back to the compressor is the condenser fan running? Make sure you thaw it completely before trying to recharge it. Also check for plugged filter dryer, and as a last resort see if it has a plugged or incorrectly sized orifice or TXV. Charge by superheat method.
Jul 15, 2014 | Intertherm P3RA-030K Air Conditioner
Machine only makes ice cubes on a few coils
Without knowing the type of ice maker you have there could be several causes for this. Low charge, metering device problem, make up water constant fill or to warm. Need more info to help.
Jan 08, 2013 | Danby DIM1524W Ice N Easy Portable Ice...
My check engine light came on i took to the mechanic he say my park plugs need to change i did but the car is still shaking when i start the engine i went to auto zone the test the car with machine the...
Hi, 305 is not ignition coil, unless you have a recent model with coil on plug. What model, year and engine do you have?
Please see my tip at http://www.fixya.com/cars/r6715318-causes_gasoline_engine_misfires . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Mar 15, 2011 | Ford Explorer Sport Cars & Trucks
Leak found in evap coil. Need to replace 2.5 ton evap coil. would like to know thw cost. Please advice
im not sure what your seer is or the type of freon you have in it this coil may no longer be available I would need more info
Aug 06, 2010 | Goodman CKL60AR60 Air Conditioner
Ice on coils
Ice on the coils can be caused by low air flow over the evaporator coil, a dirty coil, or a low refrigerant charge. First thing to do is check your filters and replace them. Second make sure the indoor and outdoor coil are clean. Third, make sure the indoor fan is running. If this doesn't fix the problem then get your refrigerant charge checked.
May 05, 2010 | Heating & Cooling
1999 dodge caravan new pcm new crank and cam sensor new coil pack new flexplate still no spark, scannner show sync problem, any ideas
If you have replace new cam sensor with no sparks and the coil are good putting out 12 volt, my guess would be the computer it self faulty. cam sensor sense the cam turning and send info to computer telling computer to disperse the charge from the coil pack to the plugs assuming relay, cam sensor, coil, plugs, and wires are good. make sure the cam sensor is put in properly and position.
Aug 28, 2009 | 1999 Dodge Caravan
Lego Creator Revvin' Riders, Motorcycles and ATVs Logo
135 people viewed this question
Top Lego Toys Experts
Tom Chichester
Bill Boyd
Are you a Lego Toy Expert? Answer questions, earn points and help others
