Aircon runs for aprox 45 minutes then timer light flickers and after a few minutes switches off but the timer light stays on
SOURCE: not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
SOURCE: Telefunken TAS 180E aircon unit, After startup the unit runs for
have 9000btu recently changed the compressor,cleaned the system,installed a drier,runs for 2days and start icing up on the
discharge,like it short of gas ,stop the unit for a while check the gas its shows 390kpa.what could be causing it not to work properly
SOURCE: aircon runs for a few
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
