Question about Danby DKC645BLS Compact Beverage Cooler
No fan on Marvel Kegerator
I have a Marvel outdoor Kegerator, that was running non-stop until it actually froze the keg. I figured that it was a defective thermostat so I pulled the unit out and found that a rat had partially chewed through a grey 22/2 wire that was running up the back of the unit (I assumed to a thermostat). I figured that this was my problem and I cut and reattached the wires with wire nuts and waited for the keg to get back to temperature and the fan to cycle off. It was a hot day and the fan never really did cycle off but for a maybe 30 seconds at a time and then restart. I then made the stupid mistake of trying to reconnect the wires with something more weatherproof and forgot to unplug the unit. I let go of the black and red lead (22/2 wire) and it shorted out when it hit the condensor coil. The fan shut off and it popped the GFI. I cut and restripped the wire but I have not been able to get the fan started again. There is power to the unit and it sounds like the condensor is working. It even sounds like it is trying to start the fan and then it clicks near the condensor and nothing happens.
What should I do?
  • 2 more comments
  • ucgreg Jul 13, 2009
    Does that just require removing the 2 (black and red 22/2) wires clipped to the circuit board and replacing it? Also, do you happen to know where I can get the parts?
    No subsequent response and would like other opionions also. This is a Marvel Kegerator 60HK-SS-F not a Danby
    Sorry, I'm new to this. I didn't realize that this would be damaging to your rating. If there is a way to re-rate you, I will. I meant no offense. I errantly thought that the experts were available like a live chat. Thanks for the help you provided.
  • ucgreg Jul 21, 2009
    Thanks, for commenting on this problem. I ordered a new thermistor and a fan and will try to put them in tonight or tomorrow. It sounds like you are suggesting that it might be at the connection to the circuit board. I checked but the wire clips to the board and they are not burned. Could it be a problem in the actual board? If so, would I have to replace the whole board?
  • 3,037 Answers
Yes, replacing the whole board is usually what is done unless you can narrow down the exact component that has burnt out or became disconnected. Let me know how this all turns out.
Benjamin
Posted on Jul 22, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Unfortunately, no wiring diagram hence could not be more specific. Still based on your description, it would most likely be that the relay contacts are burned / melted off. The clicking is significant as it indicates the relay is activating but if the internal contacts are not engaging, then there would be no voltage supplid to the fan through the red & black wires hence fan would not spin. The relay would be located on the contoller board.
Good luck and thank you for asking FixYa.
Posted on Jul 19, 2009
  • Louie  Role
    Louie Role Jul 22, 2009
    Appreciate your postback and additional information.
    On your post:
    • suggesting that it might be at the connection to the circuit board. I checked but the wire clips to the board and they are not burned - sorry, but not the wires, the "...relay contacts are burned / melted off...";
    • Could it be a problem in the actual board? - doubt if it is the entire board but would most likely be with a component on the board, the relay. It does the actual switching of the fan. It would look something like the images below;
    • If so, would I have to replace the whole board? - if the relay could be confirmed as to have burned contacts and everything else works except the fan, then it is possible to de-solder the old relay, purchase and solder a replacement. Otherwise, then the entire board assembly would have to be replaced.
    Top Expert:
  • Danby Master
  • 76,691 Answers
I THINK YOU SHORTED OUT THE THERMOSTAT CONTROL, REPLACE IT.
Posted on Jul 13, 2009
  • yadayada
    yadayada Jul 13, 2009
    SORRY DON'T OPEN EMAIL TO SEE RESPONSE EVERY MINUTE, HAVE OTHER THINGS TO DO AS WELL, BE PATIENT PLEASE. SINCE YOU RATED ME NO HELP THEN I AM THROUGHT WITH THIS FIX, THANKS
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Have not used the kegerator for several years. Plugged it in and it immediately started getting cold. Then I unplugged it to move it and when I plugged it back in it does not get cold.
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
Apr 30, 2010 | Beverage-Air Kegerator - Beer Keg Cooler...
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Danby DKC645BLS Compact Beverage Cooler Logo
323 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
