Tv approx.5-6 yrs.old,shut itself off,when I try to turn back on I get nothing!Could this be a fuse or picture tube?
    Genius:
  • 1,550 Answers
No my friend change the motor charge belt on the vcr sistem
Posted on Jul 13, 2009
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
My TV screen turns green with no picture until i turn it on and off TV is approx. 2.5 yrs old and is used very little and it seems to be getting worse thanks Kent
This tv a CRT tube tv?Or a LCD tv or a Plasma tv?The tube tv,the video board that connect to the CRT tube head have problems.The Plasma or a LCD tvs.The main board,call the Tuner board is the cause,this board,that where the incomming broascating signal cable plug into it.CRT tube tv,old technology,must take to tv shop for estimate and repair.Plasma or LCD tvs can tries websites like Shopjimmy.com or Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 19, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Samsung 56in big screen lights flashing-cuts off
theres defective caps in the power supply
Apr 25, 2010 | Samsung Televison & Video
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
JVC AV-F29MX3
You have what sounds like a failing vertical output IC also could be some bad capacitors. If you are able to solder it would cost a few dollars to try this and see if it fixes it. If not you would need to replace the whole board itself and that could cost you a little bit more money. If you need a tech it is time to get rid of it you are looking at at least 200 dollars for repair.
Feb 06, 2008 | JVC AV-F29MX3U 29" TV
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
