Question about Dell Latitude D600 Notebook
PROBLEM with the i, 8, k, and comma key! help???
I have a problem with the i, 8, comma key, and k keys . as u can see they somtimes work, but most of the time, they dont. i have to push the keys down about 50 times as hard as possible to get them to register. Is there an easy way to fix this problem?? Thanks
Joel
    Problem Solver:
  • 5 Answers
Prior to replacing the keyboard, you may just have some garbage under the keys that is preventing you from pressing it down fully, and as the laptop shifts the keys may work again or stop working.
You Can remove the keyboard per the above instructions, and clean it out well with compressed air, or as gently as possible remove the actual keys you are having issues with.clean beneath them and pop them back on after and see how well they work after. (don't use a vacume)
To put the keys back on I hook on one side and press firmly on the key until it clicks back in place with the other keys... if it is not sitting as it was before you took it off, then press more and wiggle it a bit until it is in place. Avoid breaking the little white plastic sping0type part beneath it.
Posted on Jul 15, 2009
  • 3 Answers
If some keys on your keyboard aren't responding, the sensor under the key may be going bad. Fortunately replacing the entire keyboard for your Dell D600 is not very expensive. I recommend the keyboard at this web store:
http://www.machinaelectronics.com/store/buypart/Dell_Latitude_D600/1M722
To install a replacement keyboard, the plastic panel above the keyboard would need to be removed, which may be held on by some screws from the underside of the laptop. Then you can access the keyboard screws, and gently remove the keyboard cable from the motherboard.
Posted on Jul 14, 2009
HP 15C commas and decimals interchanged
Turn the calculator off, press and hold the decimal point key, press ON, then release both keys.
Apr 20, 2013 | HP 15C Scientific Calculator
I am trying to program a TI-82. I cannot find an arrow key --> or a comma. Please help
The arrow is the STO key just to the left of the 1 key. The comma key is just above the 7 key.
Nov 20, 2010 | Texas Instruments TI-82 Calculator
On the TI-84 Plus Silver Edition, there is no Comma indication above any of the keys! Any idea where it is, or does it even exist? Looks like it should have one.
Don't look above the keys, but at the keys themselves. The comma is not a shifted function, but the primary function of the key located just above the 7 key.
Oct 19, 2010 | Texas Instruments TI-84 Plus Silver...
HOW,AFTER DIALING A NUMBER,DOYOU ENTER A PIN #?
using a comma ',' for evey three second delay you need until the PIN needs to be keyed.
so for example:
8005551212,,1234 will dial the number 8005551212 wait 6 seconds then dial 1234
you can key in a comma by holding down the * key until it changes to a comma
Sep 26, 2010 | Apple iPhone 3G
Where is the comma key on the ti 84 plus silver edition?
Here is a picture of the keyboard. The comma is in the column of keys below the MODE button. In this column, the comma is between the sine function SIN and the key for the number 7. To its left is the square (x^2) key and to its right is the left parenthesis (.
Aug 24, 2010 | Texas Instruments TI-84 Plus Silver...
Some keys doesnt work like the comma dot question
the problem may be of the sticky keys or of the keyboard. no else problem is seen in the keyboard.. so, if sticky keys are enabled, disable it from the accessibility options in control panel else change the keyboard !
May 08, 2010 | Gateway MX7120 Notebook PC Notebook
How do I type question mark and slash on this keyborad
Look to the right of the N and M and COMMA and PERIOD keys, for the SLASH key.
Below the COMMA and PERIOD keys, is there a key labelled ALT(ernate) GR(aphic)? If so, hold that key down, press the key to the right of the PERIOD key, and press the ALT GR key, and see if a SLASH is displayed.
May 07, 2010 | Dell 0Y3740 Keyboard
Can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
  1. Press the 'ON' key;
  2. Press the Integral key b8325f5.jpg;
  3. Enter your expression (example X^2+X-3 etc);
  4. Press the 'comma' key after your expression;
  5. Input the first limit after comma, input comma again after first limit;
  6. Close brackets;
  7. Press the equals key, display may return after a while with the answer.
for eg to calculate xdx from 0 to 2, input as follows:
dx(X,0,2)
To calculate derivative at a point:
  1. Press Shift and then the integration key.
  2. Enter your function;
  3. Input comma;
  4. input the point at which you want to evaluate the derivative;
  5. Close bracket and press enter.
Example, to calculate d/dx X^2 at 3 input:
SHIFT+dx key X^2,3)
Display looks like this: d/dx(X^2,3).
Oct 23, 2009 | Casio FX-300MS Calculator
Comma key on TI-84 Plus Siver Edition calculator.
The comma key on the TI 84 SE is above the 7 key, and it is just left of (, right of x squared, and below SIN. thats where the "," key is. If you're asking something else, please clearify. My understanding is that you don't know where the comma key is.
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
Sticky keys
Your keyboard needs cleaning.RICHARDM69
Oct 16, 2008 | Compaq Keyboard
Dell Latitude D600 Notebook Logo
363 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
