Question about Acer Aspire 5000 Notebook
My acer aspire 5000 overheats and shuts down frequently. is there a solution for this?
  • 909 Answers
If this has recently started then it may be something simple like dust and fluff in the "cooling path". Vacuum out or blow out with a can of air, if the problem persists, you could purchase a cooling pad that plugs into the usb or a self powered one(£15-$20) or so, very cheap on E-Bay.
I hope this helps.
Posted on Jul 13, 2009
  • Acer Master
  • 4,924 Answers
Either it has a temp protection set on bios.....and its shuts down when it reach on that temperature ....( i mean the CPU ) ..in this case just go to bios set-up ...on boot by pressing del and remove any temperature limits if it has ...or try also to restore the default (manufacturer settings) from there ..if you arent able to locate that temp cpu limitator
if after this it still does that ..it means that your cooler either do not work anymore ...but inthis case the shuting down should be almost imediate after boot...either do not work proper...and it needs to be replaced...
but my money will be on the top temperature seting from Bios...and it is shuting down auto when get to that temp ..
good luck !
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
My acer aspire 4930 laptop shut down frequently while working
Hi
Maybe you are using this laptop for a quit a long time now without cleaning? you need to clean the exhaust fan. As the thermal protection shuts down the system once the temperature reaches its limits. Cleaning the fan will solve the problem.
Aug 01, 2011 | Acer Aspire 4930-6862 Laptop
My acer aspire 5050 shuts down after using it for 20-30mins
CLICK HERE to know the causes of your laptop heating and how to solve it....
Good Luck.. :)
Jul 18, 2010 | Acer Aspire 5050-3242 Notebook
My Acer Aspire 5000,keeps shuting itself down during startup
this is an indication that your computer has so many dust build up inside, CPU or the processor generates heat, even when in start up mode, when the heat doesn't dissipates somehow, there is a protection that will shut off electrical circuits to prevent further damaged to your whole computer.
that is why it is shutting by itself automatically. chances are there is a lot of obstruction in the cooling system, particularly the heat sink.
you need to send this to a technician, im afraid
hope this helps
Jan 08, 2010 | Acer Aspire 5000 Notebook
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
New fan starts and stops on a rebuilt Aspire 5000
maybe its set from bios to start at a certain temp ...get bios settings to optimal default ...
Aug 01, 2009 | Acer Aspire 5000 Notebook
Aspire 5000 turns-on and after 5 sec it shuts down
Sounds like Hardware fault but I have found a number of laptops where they were infected, So ot be sure start the laptop in safe mode by pressing F8 every 4 sounds a couple of times select safe mode, did the laptop shutdown? Regards GeWiz
Jun 13, 2009 | Acer Aspire 5000 Notebook
My acer aspire 5720 overheats and shuts down
You cooling fan may be faulty (ie. stop spinning) or the heatsink and or fan is clogged with dust.
Apr 04, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 1360 + Shut down frequently
is it hot when your laptop shut off ?
if it is, try to clean you cpu fan and heatsink
Apr 23, 2008 | Acer Aspire 3610 Notebook
Acer 5002 laptop shutoff randomly
Have your DVD Rom checked..I had a similar problem XP not loadin... It was because of compatibility of the rom... like wise it could be a mother board problem..
have it checked up by an acer service person
Oct 16, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5000 Notebook Logo
261 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
