I cant hook up me x box 360 to my rca tv - Televison & Video
  • jason_mucci Jul 13, 2009
    the tv wont turn to any of the those channels just 1-99
  • 3,230 Answers
Check the below lin -
http://columbiaisa.googlepages.com/diagrams_hookup_xbox360.htm
Here is full information with images...
Good Luck!!
Please do rate this solution.
Thanks
Posted on Jul 13, 2009
  • 13,433 Answers
Can you post the model of your RCA tv and also what cables are you using?
  • Ekse Jul 13, 2009
    On the back panel of your TV
    There is a VIDEO, AUDIO R, AUDIO L/mono
    Connect the 3 wires, yellow, red, white into these 3 connectors.
    Turn on the console.
    The channel you need to turn on is most likely 0. or EX0 or EX1 (ex01) OR AV, AV1. Similiar, go over the channels you have.
    You should get picture from the console.
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )
you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
Dec 27, 2012 | Atari 2600 Console
I Have A 1998 Daewoo Tv Model DTQ-20N2FC, And I Cant Find Where To Hook Up My Dvd Player On It! Can You Tell Me Where It Is? -Thanks!
If you unit don't have RCA (push on jacks), then you will have to buy a RCA to coaxial converter box.
Jan 21, 2011 | Daewoo DTQ-20N2FC TV
I hooked it up the way the manual said and it doesnt work
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
May 01, 2010 | RCA RT2380 Home Theatre System System
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
The inputs on my tv arent workin, how can i hook my xbox up to alternate sources in order to play?
Well you need a TV. What happens when you connect check the switch on the AV cord that plugs into the 360. If you have no RYB or rca ports that work on your tv buy a nice used CRT tv from cragis list for 20-40 $
or check http://rns-systems.com/ for a used LCD
Oct 16, 2009 | Microsoft Xbox 360 Console
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
May 21, 2009 | RCA TruFlat 27F520T 27" TV
Can't get sound to play on my x-box
you might check the cords because some people get the two red cords mixed up and plug the audio into the wrong hole try switching the two red cords. this is only if you are using the hd cords
Apr 20, 2009 | RCA TruFlat 27F520T 27" TV
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
