Question about ViewSonic PJD5123 3D Projector
How do I fix Viewsonic PJD5123 color problem and powering-itself-off problem?
Wwhen I start the unit -- the image constantly flickers for 10-20sec, stops on a random color and the projector lamp turns off. The lights are showing problem with cooling system. The projector lamp is brand new and all the fans are clean, no dust inside. Any suggestions?
techman
  • 3130 Answers
SOURCE: Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
Posted on May 10, 2006
techman
  • 3130 Answers
SOURCE: Image flickers
It sounds like the socket that the bulb goes into has an intermittant connection problem, or where the wires attach from the bulb socket to a plug or printed circuit board connection, or possibly a bad connection in the bulb driver circuit. Good Luck.
Posted on Mar 19, 2007
BingoDabbers
  • 102 Answers
SOURCE: viewsonic pj 800 projector
Yes.
Posted on Oct 06, 2007
  • 125 Answers
SOURCE: lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
Posted on May 30, 2009
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
Why is my picture only black and white.
What is you input source connection type ?
Is it HDMI, Composite RGB or VGA etc ?
Oct 03, 2016 | ViewSonic PJD5123 3D Projector
My ViewSonic pjd 5123 dropped off table and no picture
What's your question? Apparently you broke it so who can possibly say what the damage might be.
Jul 08, 2015 | ViewSonic Office Equipment & Supplies
Viewsonic pjd5123 projector- im switching from coaxail cable to video and it doesnt show any image
can u clarify whwat u are trying to do
i assume u are trying to convert HD digital video to analog composite video
if yes , that wont work
instead ask for a coaxila to vga convertor and it should work well!
Jan 17, 2013 | ViewSonic PJD5123 3D Projector
My projector (viewsonic pj452) started flickering. When it started it would flicker once in around 5 minutes but now it happens many times in a minute. I tried resetting it from the menu and through reset...
The power supply needs to provide a constant current flow
to the lamp. Any small change or in the current will be seen as flicker
in the lamp and projected onto the screen.
Problem could be with low voltage power supply, the ballast or the
lamp it self is beginning to wear out.
Jul 15, 2010 | ViewSonic - PROJECTORS - PJ452 1500 LUMEN...
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
Image flickers
Mar 19, 2007 | ViewSonic PJ755D Multimedia Projector
Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Dec 11, 2006 | ViewSonic VX910 19" LCD Monitor
May 07, 2006 | ViewSonic Projector PJ802 Pro Multimedia...
ViewSonic PJD5123 3D Projector Logo
96 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
