Sewing Machines Logo
L
Linda Schetzsle Posted on Oct 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Old Bernina 830 walking foot not pulling item through.Lever not letting foot down completely but can push it down the rest of the way with my fingers
This happened very suddenly and I can't seem to rectify this? Have oiled and cleaned, to no avail.
Neal Iund
Level 2:
Scholar:
New Friend:
  • Bernina Expert 56 Answers
  • Posted on Nov 02, 2015
Neal Iund
Bernina Expert
Level 2:
Scholar:
New Friend:
Answers
56
Questions
0
Helped
21770
Points
127
Hi Linda:
Does your 830 have a black needle clamp and screw instead of the standard nickel plated clamp? If not, the walking foot forked driving lever may be damaged by having used the machine with zigzag engaged. Another problem with older 830 machines is that the needle clamp has been repeatedly tightened very tight, causing the needle bar base to become damaged so that the clamp is no longer perpendicular to the direction of sewing...In other words, the clamp sets crooked on the needle bar.
The black clamp made for the walking foot had a specific diameter for the forked driving lever of the walking foot. The black clamp was also longer so that when using a wide stitch width, the driving fork of the walking foot did not collide with the needle bar clamp screw on the right side.
Please reply with your observations.
How to remove the top cover of Bernina 830. My machine keeps telling me to rethread. It stitches about 10 stitches then stops
Which Bernina 830 are you referring to? (Yeah, it was crazy of Bernina to use the same numbers to identify different models...). There is the old Bernina 830 Record and the new computerized Bernina 830.
Have you tried rethreading the machine? If so, be sure to ALWAYS RAISE the presser foot. Verify the thread path is correct.
1helpful
2answers
How do i get the walking foot to glide onto the sewing machine
It sounds like you are trying to attach a walking foot to your machine. Usually when you install your waling foot the needle clamp screw pushes against the lever. This lever is spring loaded. To avoid fighting the spring you can lower the needle into the hole on the walking foot and then attach the foot to the ankle.
2answers
I Have a bernina 830 and the foot doesn't come down or up how do I get it working again?
Have you followed the maintence standards (oil schedule). If not
that may be the issue. A wild guess (at least this was the issue
recently with wife's older White machine. The foot lever was catching on the thread cutter device. Otherwise, perhaps a screw has come loose somewhere in the lever and or foot. Good luck. Double check your manual troubleshooter section.
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
1helpful
Broken take up lever bernina 830
contact a sewing machine repairer(Bernina authorised )for the part number and part availability and possible cost for repair.
3helpful
3answers
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
5helpful
2answers
Bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
