Question about Samsung Office Equipment & Supplies
Model ML-2010 printer. When receives a print job paper feeds in 1.5-2 inches and stops and get message. Have gotten blank paper to feed thru after getting message without any tinkering with printer.
  • jonahflyer Jul 13, 2009
    Sorry I left out the message. Had keyed it once but not to you.
    The message that shows up is "LSU error" on computer screen and the Online/Error light on the printer turns red.
  • Samsung Master
  • 13,433 Answers
What is the message you receive?
Posted on Jul 13, 2009
  • Ekse Jul 13, 2009
    Alright turn it off and unplug for 5 minutes, plug it back in and turn it on, see if the error comes back if it doesn't then your OK. If it does come back you have a problem.
    I was looking around our fixya pages and I found this note about the LCU error message
    The Laser Scanner Unit or LSU is what writes to the surface of the
    drum. The glass above the cartridge inside the machine could be dirty.
    The mirror motor in the LSU could be bad or needing cleaned so it spins
    better. Laser diode could be bad.
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
I just purchased a Lenovo desktop pc with windows 7 and microsoft office 2010 and the Lexmark e260d printer. Printer is working fine through the tray with all the software. I am having a problem...
Have you checked the cable? Or is it a wireless printer? If it has a cable, check if it didn't get damaged. If it has a display, check it for a error message. You can also check Lexmark's site if they provide information. And don't forget, google is your best friend.
Apr 20, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
