Question about Mastercool Heating & Cooling
We recently bought a MasterCool P700 evaporative cooler. We discovered that we could turn off the display light (makes sense with the large blue light lighting up the entire room at night) by hitting the power button a 2nd time after choosing selections (cool, sweep, etc.) However, it works only on an intermitent basis. sometimes, hitting the power button the 2nd time simply turns the cooler off. This feature is not covered in the manual. Please advise.
SOURCE: Night Service Button
Sounds to me like "inspect" might be the button programmed on the phone. IF the button is labeled "night" then you can reprogram the button.
press "SPKR # 0 0"
Press the button labeled "Night"
Press "* 3 9"
Then press the "home" or "exit" button.
See if that works...
Posted on Dec 21, 2007
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
Posted on May 08, 2009
Ed Phillips
  • 11 Answers
SOURCE: New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
Posted on May 31, 2009
co7196
  • 3433 Answers
SOURCE: water pump size and over saturated pads
Louis, The cooling does not come from the volume of water running over the pads. It cools by cooling the air passing through the wet pads. So, Yours is an impeccably logical argument that leads to a false conclusion. Bigger is not better in this caThe fishy smell is from the matting (pads) when kept saturated, Molds and algae will form if there is too much water also.. Best you get the original size pump Good luck and stay cool - Ned
Posted on Jul 26, 2009
Do they make some kind of transition for the side discharge MasterCool MasterCool Evaporative Cooler, ASA71 So when I cut open the side of my house I have a way to vent it thur the wall. Is there a kit...
Best way is to get a sheetmetal shop inyour area to make one for you.. Give them the exact size of the opening and then tell them you want a 3/4" flange all the way around and make sure the duct connection is what you need.. Let us know if you need anything else.. please vote.
Sep 05, 2010 | Mastercool 67680 Evaporative Cooler Air...
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
We have a champion mastercool evaporative cooler single inlet ASA 71 ordered from Home Depot. I am having a hard time finding a 2 speed 1 hp motor for it HELP!
Hi, I am surprised Home Depot didn't have one as this is a very common motor. I don't know where you are from, but if you look on lone for Grangers supply, or Motion industries, they will have this motor for sure. They both are large suppliers of anything you need in this line of parts. This is a very common motor, totally sealed bearings and body with adjustable sheave, ( pulley ). Please let me know what you find. I will be here to help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 14, 2010 | Mastercool 67680 Evaporative Cooler Air...
Does it need to be cleaned, if so. how is that done? AdobeAir /Mastercool model P700 serial number B150809633
Yes, it needs to be cleaned. Go to your local home store and (in the evap cooler section) pick up a bottle of evap cleaner/scale remover. Just follow the directions on the bottle. It will last MUCH longer with proper care and cleaning.
Jul 06, 2010 | Mastercool Portable Air Conditioner
Need replacement pads for mastercool mrc55wa evaporative cooler
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
Sep 18, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water pump size and over saturated pads
Jul 25, 2009 | Mastercool 67680 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
349 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
