Question about Whirlpool Dryers
Dryer does not dry as fast as it used too. Takes two cycles to dry a big load. Filters and exhaust are clear, and blower is still blowing. Looking in heat element, seems like botton 1/3 of coils don't turn red. ??
  • Whirlpool Master
  • 4,655 Answers
Then part of the heating element is most likely not working because it is burned out or the high heat setting on the control no longer functions. Let me know the model number located most times inside the door on the wall of the door opening. That way I can Help you better, Thanks, Sea Breeze
Posted on Jul 13, 2009
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Hello my dryer takes 3 hours to dry a full load is that normal
check to see if your exhaust vent is clear of lint or blower shroud is clean. you will have to get a technition to check blower or DIY.
Sep 11, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have the matching cabrio washer and dryer... although it is built for large loads I am still of the mentality of the common size loads. The problem is in the dryer on any of the sensing setting it oes...
You have a lint blockage internal of the dryer.
Cut and paste this Factory Service manual to access the dryer internal parts and clear the blockage.
Check the internal lint vent and blower wheel attached to the motor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5778291b5b00aa40852571b5005435db/$FILE/8178584.pdf
Aug 08, 2010 | Whirlpool Dryers
The dryer is not as hot as it should be.takes hours to dry a load of clothes.
the problem is your wall exhaust vent or dryer exhaust or both is clogged with lint,if it vents out the roof most people remove the dryer hose get what they can get out with there hand,then remove the roof screen and blow it out with a leaf blower,if it goes out the wall do the same thing,but first check the outside for dryed lint ball around the exhaust-mike
Mar 07, 2010 | Kenmore Dryers
Takes 3 cycles to dry clothes
This is a potentially deadly scenario. If the clothes are warm but just not getting dry, there is a problem with air flow - specifically - the lack thereof. The chance of fire is a real concern.
Make sure the lint baffle / trap is clear. This should be checked / cleared after each drying cycle. Most folks know about this, but I included it just in case this is your first dryer.
If the the baffle / trap looks clear, the exhaust tubing of the dryer is suspect. Many installations consist of the flexible / expandable hose. This hose may have become crushed during the running of the dryer, reducing air flow. Locate the hose and pull the dryer away from the wall to inspect, expand or replace the hose as needed. If an old installation, it is very possible that the hose has become clogged with lint build up over the years. The hose should be replaced in this case.
If at all possible, use aluminum expandable dryer duct. It is less likely to collect lint as quickly as the flex plastic style.
If the clothes are not warm or hot, the heat source (electric heating element or gas flame - depending on type) has a problem. Either of these problems should probably be referred to a pro for proper repair.
Jan 20, 2010 | Kenmore Dryers
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
My whirl pool dryer has to be turned on bout 3 to 4 times
Ok, check the exhaust hose for obstructions. make sure the blower assembly is not clogged and, the hose is clear of any debris. the exhaust hose should blow out hot air forcefully. if the force of the air isn't blowing hard, it will not create a suitable drying environment for the element. this poor ventilation will also damage the heating element or burner Assembly.
Now, if there is sufficient air flow out of the exhaust hose, this will confirm control failure. replace the dryness sensor and control board in this case.
Here's a quick way to test for clogs. take the hose of the backside of the dryer then, start the cycle. if the drum sorts to become hot after a few minutes with the exhaust hose removed form the back of the unit, this will confirm a major block in the hose or blower assembly.
May 29, 2009 | Whirlpool Dryers
HEATING ELEMENT DOES NOT STAY ON. EACH LOAD TAKES TOO LONG TO DRY, (SEVERAL CYCLES).
Ok, check the exhaust hose and blower assembly for clogs. make sure the exhaust vent is free of any debris. it shoudl blow forcfully out the hose. if the exuast hose is clear of any obstruction and, the blower assembly is clear as well, replace the timer/control module.
May 28, 2009 | Whirlpool Dryers
TIMMER RUNNING BUT NOTHING DRY
Q - Dryer takes too long to dry or multiple times to dry a load
A1- Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat orpocket  thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Whirlpool LER5636P Electric Dryer
My dryer takes forever to dry clothes!
it could be the vent pipe is clogged. check that out too
Jul 05, 2017 | Maytag Dryers
Dryers Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
