I am installing a Dometic Brisk 2 AC unit in my rv wanted to know if it can be operated using an inverter.
Ac compressors do not like the modified sine wave inverters. Yes it will work if the inverter and battery bank you have in place will allow for 16-19 amp draw on startup. 11-14 amp load continuous draw. This is measured per minute not per hour.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
