Question about Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
Can i hook up a intex pump to a sand filter - Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
Posted on Jul 13, 2009
  • ernest frasier Apr 09, 2011
    Your better off just getting a ezcleanfilter,then you can just keep cleaning instead of replacing.
Yes i hooked mine up when the other pump went out
Posted on Jul 02, 2012
    Problem Solver:
  • 15 Answers
Sometimes u wont be able to hook an intex pool pump to a sand filter, the pump has to big enough to pump through the sand and i think that intex pumps wont be strong enough. I may be wrong i would ask my some1 at my pool supply store. Tell them what kind u have and see if it is compatible to pump with a sand filter. But the last person that posted a solution is right, a sand filter system is very expensive but i found mine on eBay. Brand new. Alot of people think eBay is nothing but used stuff but its not, alot of stores sell stuff on there brand new. I saved aroind 350 dollars on my filter system. the whole system filter and pump varies on what size u need but for a 2500 gallon pool i dont think u would need a big one, probably around a 14 inch with a 1/2 horsepower, maybe smaller if they make them. It would prolly run u between 200-300 dollars for the complete system brand new for that smaller size and of course the bigger u go the more expensive and its according to what brand u get...i hope this helps and good luck! I tell u know that a sand filter will save u in the long run, u only have to replace the sand every 2-d years and i know when i had a cartridge filter system was cleaning them out everyday and replacing them every 3 or 4 days and it still didn't keep my pool clean like i wanted. And another advantage is if u ever get a bigger pool then u wont have to purchase a sand filter
Posted on Jun 28, 2010
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
  • 93 Answers
SOURCE: intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Posted on Jun 16, 2009
Coastsider
  • 331 Answers
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
  • 22 Answers
SOURCE: pump shuts off after a minute and isn't filtering water
there is something blocking the passage of the water, go through and check all the passages for any kind of blockage
Posted on Jun 17, 2010
I have a new Intex sand filter 3000gph I shut it off to backflush it and it will not turn on its not the electrical source any suggestions?
Intex 2650 gal/hr Sand Filter Pump Setup Instructions ...
? 10:52
www.youtube.com/watch?v=uS_95spxFaM
Feb 3, 2011 - Uploaded by Blue Fade Marketplace This video show in detail how to setup the Intex 2650 gal/hr Sand Filter ... 16" Intex 2650 gph Pool Sand Filter Pump Instructional Video 56671 ...
Jul 23, 2015 | Intex Garden
70110 sand filter. how do I connect a vacuum hose?
hook up to your skimmer over the basket to catch leaves
Jun 24, 2015 | INTEX Sand Filter Pump
Intex sand filter is noisy
these pumps on these things do make a lot noise (so much i found it's scare's deer from my yard thats eating my apple trees)
air trapped inside sand filter makes noise as well this will work it's way out after time
Jun 22, 2014 | INTEX Sand Filter Pump
Intex sand filter pump making louder noise than normal?
Air trapped in filter carrrrying over to pump ??
Jun 17, 2014 | INTEX Sand Filter Pump
HOW TO HOOK SANDFILTER UP
out of the pump to in of the sand filter out of the sand filter to in of the pool
Jun 07, 2014 | Intex 2500 Gallon Sand N Sun Pool...
Sand in little window on intex sand filter
That is not too alarming, if you are getting sand in the pool under the return line, then you could have a broken lateral assembly in the filter.
May 16, 2014 | INTEX Sand Filter Pump
My sand filter, which I just bought this summer, quit working. I turned it on, it ran for a few minutes, then quit and never came back on.
That is because it is not really a real industry rated pump/filter set up. I would not invest in same type. Spend a little extra and get a real industry rated system. You can call your local pool/spa supplier and they can hook you up with a relatively inexpensive Real pool pump & filter assembly. You will not regret it one bit! Make the move & upgrade away from that type of toy.
Sep 01, 2013 | INTEX Sand Filter Pump
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
How do I hook up a hayward sand filter to a Intex pump?
out of pump to in of filter out of filter to return of pool
May 22, 2013 | Hayward SAND FILTER, PRO SERIES
Intex sand filter has low pressure
to low a pressure on a sand filter most often is caused by a improper sand charge inside it
Sep 21, 2012 | INTEX Sand Filter Pump
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Logo
701 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
