Question about Frigidaire GLGQ2152ES Gas Dryer
Turns on but wont heat up
Frigidaire Gas Dryer GLGQ2152ESO turns on but wont heat up
Thanks Denise
  • 6,784 Answers
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jul 13, 2009
My Frigidaire Crown electric dryer isn't heating. The drum turns but no heat! HELP!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLER341A Electric Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Dryer turns but has no heat, fuse location?
heatman101
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Gas dryer does not heat
The reason to this problem is due to the faulty
heating element.It needs to be replaced.
Sep 01, 2009 | Frigidaire GLGR331A Gas Dryer
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Nov 29, 2008 | Frigidaire Dryers
Frigidaire GLGQ2152ES Gas Dryer Logo
799 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
