Question about HP DesignJet 5500PS InkJet Printer
Error hpdesigjet 5500
Error del sistema: 010092 0310050d
  • agungligasap Mar 07, 2010
    how can i get scematic diagram power supply hp designjet 5500,??
  • Anonymous Mar 17, 2014
    040000 02730803
  • 100 Answers
The error is reported because the positioning point of the main spooler cannot be detected. During self inspection upon startup, the plotter needs to detect the starting point of the positioning main spooler, namely, the Mark point. If this is not detected, the above error code is reported. SOLUTION: Replace the Lens Cover If the Lens Cover of the pen carriage is polluted during the operation, reading the Mark point will be affected. Therefore, replace Lens Cover via the menu operation. First, access the printer Setup Menu, and then access the Utilities menu. In the menu, select:Lens Maintenance option. Now the pen carriage of the printer will move out automatically, and prompt you to left the upper cover. Take out the standby Lens Cover (in the sponge of the upper cover of the printer), and then take out the old Lens Cover (below the right side of the pen carriage) on the pen carriage, and replace with a new Lens Cover. Restart the printer. If the printer does not return to normal, contact the local gold-level service center or HP800 technical support center.
Posted on Dec 23, 2009
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
Apr 04, 2011 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
TENGO UN BLACKBERRY 8310 Y PRESENTO UN ERROR error jump 517 reset
Hola
Intenta volver a cargar el sistema operativo en el teléfono y restaurar los datos desde las copias de seguridad.
Antes de decir "cómo" hay un hilo sobre la carga del sistema operativo que es stickied.
Jan 13, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
Pasos para instalar en board msi kt4v 8x
suena como yo tenía los mismos problemas que tenía con mi geforce 5200 que no fue la instalación bien. qué sucedía era el x directo ataba al viejo sistema de gráficos de tablero de madre y no a la nueva tarjeta. para hacerle el rebind apenas cambie la tarifa de restauración en el icono del nvidia en su barra de tarea. inhabilite el adaptador de exhibición del encargado de dispositivo para los gráficos .put de la placa madre la tarjeta en el cambio de la ranura el cheque ascendente del cargador de la cuerda del monitor usted x directo mecanografiando en dxdiag funcionado y directx de la prueba a estar seguro que está funcionando con su tarjeta que usted puede también ver que alrededor del nvidia usted debe tener el conductor para la tarjeta instalada para hacer todo el esto. la esperanza I ayudado para instalar el conductor primero entonces inhabilita los últimos conductores aquí http://www.nvidia.com/Download/index5.aspx?lang=en-us de la transferencia directa
Dec 28, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
System error E000 canon pc 1060
That's not a good number. Your fuser unit has a fault and is not heating up. It does need a technician at this point.
Dec 20, 2009 | Canon PC-1060 Black and White Copier
Tengo una Nueva Acer Veriton M460 core 2 duo, vista bussines,Disco Duro Seagate 320GB, se hizo downgrade a Win XP PRO, no funciono, volvi a recuperar disco duro, hize lo mismo y no funciono, instale el...
La instalación del HP Compaq no funciona en la máquina nueva porque el sistema (hardware) es completamente diferente.
La mejor manera de hacer el "downgrade" es instalar el sistema operativo desde el comienzo, borrando cualquier partición que exista, donde está el sistema operativo instalado que no funciona. Para eso se necesita el CD o DVD con Windows XP SP2. Esto se hace activando la opción en el BIOS de la PC para que lea el CD o DVD antes que el disco duro. Una vez dentro del programa de instalación, hay que descartar la instalación anterior borrando la partición y volviendo a crearla, usando los íconos del programa.
¡Buena suerte!
Dec 01, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
Recuperacion de sistema
COMIENCE, FUNCIONE, MSCONFIG, LENGüETA de Boot.ini Las 2 trayectorias del cargador se deben enumerar allí, y la que doesn' el trabajo de t se enumera como DEFECTO. Destaque la trayectoria funcional del cargador, chasque el SISTEMA COMO botón de DEFECTO, entonces AUTORIZACIóN
in English:
START, RUN, MSCONFIG, Boot.ini TAB The 2 boot paths should be listed there, and the one that doesn't work is listed as DEFAULT. Highlight the functional boot path, Click the SET AS DEFAULT Button, then OK
Jun 25, 2009 | Dell Dimension 8400 PC Desktop
CD RESTORE DELL DIMENSION 1100
La mejor manera de hacer esto es reinstalar el sistema operativo entero del rasguño. No hay restablecimiento de la PC para este sistema ni pudo ser dañado muy probablemente ya si usted tenía uno. Para probar, presionar ALT+F11 cuando usted enciende la computadora en la insignia del dell. Si esto no trabaja, usted necesitará insertar el CD de la reinstalación de Windows en la impulsión y cambiar formato su sistema entero y comenzar del rasguño. Después eso. usted necesitará instalar los conductores y las utilidades para el sistema del dimensiono.
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Error en sistema 0013 en BenQ DC610
CBCX, efectivamente el error se debe a que el lente se trabo y no pasa las pruebas movimiento iniciales que hace el equipo al encender. Por esta razón aparece el error de 0013. Mi experiencia a sido que el engrane que provee de este movimiento se sale de su posición original provocando que se trabe. Yo tengo una cámara del mismo modelo. El problema se resuelve abriendo la cámara y ajustando el engranaje (Es un pequeño engranaje rojo que esta en la parte superior del lente). Adicionalmente se debe fijar el soporte del engranaje, yo coloque un poco de cinta adhesiva en el soporte del engranaje para que no se mueva nuevamente. Esto en la mayoría de los casos resuelve el problema de manera permanente. Adicionalmente es recomendable actualizar la última versión de firmware del equipo.
Como referencia, he descubierto que si estas en el campo tomando fotografías y te ocurre el problema, si le das un golpe firme con el pulgar, en la parte delantera de la cámara justo entre el flash y el emisor para el ajuste del foco el problema también se solventa de forma temporal ya que el engrane entra nuevamente en posición. Puedes hacerlo también dentro del estuche de la cámara con la palma de la mano. A pesar que esto nunca falla, el equipo queda funcionando nuevamente, esta reparación es de carácter temporal y adicionalmente, es obvio que no es sano recomiendan esta práctica, pero puede salvarte en caso de que estés de viaje tomando fotografías y no tengas un servicio especializado.
Feb 03, 2009 | Nikon Coolpix 3200 Digital Camera
Conon ir2016 error E808
la fotocopiadora se bloqueo y no sale del error 803 es una canon 400s
Apr 29, 2008 | Canon PC-940 Black and White Copier
HP DesignJet 5500PS InkJet Printer Logo
598 people viewed this question
Seeker5211
Seeker5211
