Question about Kodak EasyShare Z612 Digital Camera
Kodak easy share z612 will not turn on to take a picture
I took pic and battery went dead and camera will just turn on and off and leave the lense fully extended but i cant take a picture???
  • iddnmw Nov 21, 2008
    Lens is fully extended. Battery is fully charged. Camera will not stay on and lens will not retract.
  • JOAMALFI Dec 29, 2008
    kodak z 612--i turn it on and it tries to load then error code 45 immediately appears on screen lens is fully extended and battery fully charged--turn it off and lens does not retract--initially happened when i was transferring pictures to computer from camera it was almost done when this code came on and it would no longer transfer and screen locked
    joamalfi@netzero.com
  • 48 Answers
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Posted on Nov 16, 2007
I have a kodak easy share camera M340 and I can't take any photos since it says Internal memory is full. Help
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
Sep 10, 2011 | Kodak EasyShare Z612 Digital Camera
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
When trying to upload my pics, computer says can't locate device
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 09, 2009 | Kodak EasyShare Z612 Digital Camera
Kodak lense adaptor 49 to 55 mm
kodak z-612 , z-712 , use 52mm to 58mm adapter. a z-712 has threads they are had to see but there there.
Oct 28, 2008 | Kodak LENS ADAPTER 49 TO 55MM Lens...
Horizontal lines running through pictures.....Z612.
I've had sinilar problems with mine. I bought it in November of 2006 and sent it back to Kodak (under warranty) 3x before they finally agreed to replace it (with a refurbed unit). Well, that was in June of 2007 and the problem is now baaaack with the reoplacement camera (same model)... I'm requesting Kodak replace it with another model, but I'm "out of warranty" and they want me to pay them $145 to repair (which they've never been able to fix for me). So I am requesting them to replace with a different model.
May 15, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Error #803
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Apr 10, 2008 | Kodak EasyShare Z612 Digital Camera
Lifeless Camera
I wish I shared you easy solution feeling. Try a few things Take battery out and clean the contacts at the base of the chamber with a pencil eraser. Ditto on the chamber door. If nothing happens try charging the battery in another charger or another battery. Still dead? Kodak support is the next stop
Sep 19, 2007 | Kodak EasyShare Z612 Digital Camera
use the "MENU" button and follow the program to reset your camera to its card memory. evidently you must do this each time you change cards or battery.
Jul 25, 2007 | Kodak EasyShare Z612 Digital Camera
Lines on the LCD Screen when pics have been taken
See the other solution with the same camera. Same exact problem.
Apr 08, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
387 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
