Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Sears 17.5HP Lawn Tractor (about 5 years old After cutting grass (takes about 20 minutes)when I turn off the engine for 5 minutes or so it will not restart. Battery is strong and engine is turning over but not starting. After sitting in the shed overnight the engine starts right up. Any ideas?
  • 21 Answers
Re set youre valves intake 0.6 exhuast0.4 that should take care of youre prob
Posted on Jul 13, 2009
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I try to start my craftsman lawn tractor.when I turn the key the flywheel turns about 1/4 turn.i waitsame thing.i wait 5 minutes it will turn but will not crank. I wait a few more minutes and it...
if the engine is a briggs and strattion the valves have to be re adj to 4-6 thou intake 5-7 on the exaust i am a sears teck i see that problem quite often
Jul 03, 2010 | Garden
The mower just stopped dead.
clean and tighten all connections from the battery to the starter and selenoid connections too
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to raise crafstman tractor deck
Your deck is not installed correctly. If you have the operator manual, check everything. If yo dont have the manual ... go to www.sears.com/support and get one.
May 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Over heating minutes after starting
Take the engine cover off and check to see if there is dried grass,leaves,etc packed inbetween the cooling fins on the engine. Some animal may have decided to make a home there.
May 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
201 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
