Question about Brother IntelliFax-2820 Laser Fax
Large grey streak down center of page
We recently replaced both the drum and cartridge. For about the first 20 copies/faxes we get beautiful prints. Then it starts to deteriorate and a large grey streak appears - about 2" wide down the center, similar to a large pencil smudge. You can see where it's being made by a roller some where. Replaced the cartridge a second time thinking we a got a bad cartridge and the same thing has happened. Great copies/faxes initially, then after about 20 prints the grey streak starts to appear. Can anyone help?
  • springafling Nov 16, 2007
    Thank you so much although I'm bummed to be looking at more repairs costs after just replacing the drum and two cartridges. I should have just invested all that money in a new printer! Thanks again!
  • Brother Master
  • 1,113 Answers
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Posted on Nov 16, 2007
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
I have a Ricoh 3900L and It prints very light and streaks in the center of the page I have cleaned it and my add toner light is not on. I faxes out fine it is the incoming faxes and copies that are bad.
It sounds like you probably need to replace your toner cartridge. The add toner light is not on because you still have toner in the cartridge, but some other part of the cartridge has likely gone bad (such as the developer or the drum). Replacing the toner cartridge should take care of your copy quality problem.
Hope that helps!
Dec 19, 2009 | HHP FIXED MOUNT LINEAR (3900lx-12)
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Grey streaking on printed pages
Laser printers are charged using a drum which produces an electrostatic image. The drum could be unable to hold all of the 600v charge or be be scratched if the streaks are always in the same position the the drum is not holding the charge for the toner to attach to and therefore the drum is faulty and beeds to be replaced
May 20, 2009 | Brother HL-2040 Laser Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Printing quality problem
HELLO! IF YOU ARE USING A GENERIC DRUM OR TONER, YOU WILL HAVE COPY QUALITY PROBLEMS
Jan 14, 2009 | Brother IntelliFax-2820 Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
225 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
