Question about Intel D845GEBV2 Motherboard
Can I run 6 pci video cards and how? - Intel D845GEBV2 Motherboard
Wy u want to run 6 video cards? . . only one is enough or what ru tryin to do? cuz i need more details
and the answer is no maybe 3 in SLI modeand 2 in crossefire
Posted on Jul 13, 2009
I need a new graphics card - are they still available for this make & model and what is the name & type of card I need to buy?
https://support.gateway.com/s/PC/R/5022/5022sp3.shtml
gateway support shows you have a pci-e x16 slot for a video card
you can choose a non-powered pci-e video card for your system, which might be better for you if you still have the stock power supply in your tower.
or, you can choose a powered pci-e card if your power supply is powerful enough to run your system AND a pci-e video card too. a powered card will have a spot for a 6 pin (or 2x 6 pin or sometimes a 6 pin and/or an 8 pin) power connector that comes from your power supply to the video card ... you may have to replace your power supply to use a powered card, or get a pci-e power adapter (not the preferred method, but sometimes works).
here is an example of a non powered pci-e card
and here is an example of a powered pci-e card, see that black connector near the back of the card, that's the power connection
and the 6 pin connector from the power supply looks like this (and power supply adapter shown also)
does this help?
Aug 27, 2013 | Gateway 835GM (835GH) PC Desktop
My ATI firepro V7800 makes continuous beeping noise. PC does not boot when I turn it on.....pls help!!!
1) Believe the continuous beeping you hear is a BIOS Beep Code, stating you have a graphics problem. Computer, not video card, is beeping.
2) Do you have the external 6-pin PCI-Express power cable plugged into the graphics card, from the Power Supply?
3) IF, your Power Supply does not have a 6-pin PCI-Express power cable, are you using TWO 4-pin Peripheral power cables, connected to a 6-pin PCI-Express adapter power cable?
To wit;
6-pin PCI-Express power cable example, and also showing a 6-pin PCI-Express adapter power cable on the right,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
Example of a 4-pin Peripheral power cable,
(Misnomered by many as a 'Molex' power cable. Molex was the first company to make that type of connector. The name stuck, kind of like calling an adjustable open-end wrench a Crescent wrench),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the color code of the wires used in a 4-pin Peripheral power cable, and a 6-pin PCI-Express power cable.
Red = 5 Volt wire
Yellow = 12 Volt wire
(All are DC Voltage)
Black = Ground wire. (ALL Black wires are Ground wires)
The 4-pin Peripheral power cable has ONE Yellow 12 Volt wire.
The 6-pin PCI-Express power cable has TWO Yellow 12 Volt wires.
The most power that a PCI-Express x16 expansion slot can deliver, is 75 Watts.
"This cable is used to provide extra 12 volt power to PCI Express expansion cards. PCI Express motherboard slots can provide a maximum of 75 watts."
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
"The older 6 pin version officially provides a maximum of 75 watts (although unofficially it can usually provide much more)"
The ATI FirePro V7800 graphics card requires 150 Watts by itself.
The PCI-Express x16 expansion slot CANNOT deliver the recommended power (Wattage) needed, therefore an external power cable capable of delivering 75 Watts is needed.
What happens if you just use ONE 4-pin Peripheral power cable, in a 6-pin PCI-Express adapter power cable?
The PCI-Express x16 expansion slot contact pins -> BURN
The gold plated contact pins on the bottom of the graphics card -
BURN
The connection on the graphics card for the 6-pin PCI-Express power cable - BURNS
The contact pins in the 6-pin PCI-Express adapter power cable -
BURN
If it is too bad, and cannot be remedied by cleaning, the motherboard is TOAST, and so is the graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 30, 2012 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
May 26, 2012 | Gateway Computers & Internet
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
I just installed the palit gtx 460 sonic 2gb and am getting no display output. I am running iBUYPOWER Gamer Power 563D3 Phenom II X4 965(3.4GHz) 4GB DDR3 500GB HDD CapacityWindows 7 Home Premium 64-bit. I...
The fact that your old Palit GT220 worked shows that your system components are NOT faulty.
The Palit GTX 260 requires the following
1) A PCI-Express 2.0 comliant motherboard.
2) Two 6 pin PCI-Express power connectors.
3) Minimum 450W or greater system power supply.
Lets break this down a little
1) You already have a motherboard that supports this card so no problem there.
2) I am unsure whether your power supply has two 6 pin PCI-Express power connectors, it should have one though and the GTX 460 package should have a molex to 6 pin PCI Express power adapter that you can use for the other.
3) Now it comes to the power supply itself. Currently your system has a 480W power supply. Through some calculating it seems that a system of this spec should have at least a 550W power supply. This means that your current power supply is 70W out. This may be why you get no signal, there is enough power for allthe other comonents but not enough left over for your GPU.
Before you go out and buy a new power supply just check that both 6 pin power connecters are firmly clipped in. If after that the card still doesn't power up then I suggest you purchase a Cooler Master Exteme power plus 550W or greater power supply.
Jan 07, 2011 | Palit Microsystems Palit GTX 460 Sonic 2GB...
I wanna know that is XFX 9800gt supported on intel DG31PR motherboard or any PCI express motherboard ? I also wanna know that is it a good combination of 9800gt DDR3 1gb and DDR2 RAM 2gb?? Please reply me...
nVidea 9800gt is a good card... probably not a question of if the MB will support it as much as if your power supply will. It needs a secondary 6 pin power connection.
Any MB with 16x PCI slow will run the board. The different RAM types on the MB and Video card will nto matter as much as the throughput of the PCI bus...
2GB ram on you main board, hope you are not running anything serious.... I do a fair amount of video with a 9500GT. Quad Core 2.66, 6 GB ram and am looking to upgrade to an I7 with 12GB and a nVidia 250 or better....
Mar 07, 2010 | Pine Technology XFX XFX GeForce 9800 GT...
Will this video card run my motherboard
Yes it will.
Here are the requirements needed to run it
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode).
  • Your board has the Pci-ex16 slot and the Corsair has the power to run it.
    Jan 20, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
    I need help choosing a video card - part 2
    PCI is the older, slower format, PCIe is newer and faster, but your system MUST support PCIe or it won't work.
    So easy option is to find if your system supports PCIe and then get whichever is suitable.
    May 13, 2009 | Intel D101GGC Motherboard
    Bought a Nvidia Geforce 7800 GTX 256MB Graphics card
    errrr.... do you mean the 6 pin pci-e power plug and lead that normally comes off your Power supply?
    You can get converters leads that change the pinout of 5.35 HDD power to 6-pin pci-e but this is usually NOT RECOMMENDED for any GTX series of GeForce.
    You usually need the dedicated PCI-E RAIL (with its own PCI-E lead/connector... or even better x 2 of them) on your power supply for these builds.
    Once again.... i definately do not recommend converting one of your other power outputs to run a GTX. At best it will not work.... at worst (though unlikely) you may end up damaged your shiny new GFX card.
    If you do not have a 6 pin PCI-E lead and plug running directly from your power supply to run this card.... you need one. Do you happen to know the model of your current PSU?
    Mar 25, 2009 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
    Will this motherboard support adding a new video card?
    Yes, but it has to be strictly a regular PCI video card. You cannot use an AGP or PCI Express card.
    Here is a link to available cards through Tiger Direct:
    PCI Video Cards
    Another thing to remember is that you may need to change an item in your BIOS to turn your On-board video off.
    Thanks for using Fixya.
    Mar 20, 2009 | Gateway Computers & Internet
    Intel D845GEBV2 Motherboard Logo
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
