Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine is saying f 5 and wont drain or pine but it will wash
    Problem Solver:
  • 13 Answers
F5 means pressure switch jammed on full , check filter and pump for blockages.
Posted on Jul 17, 2009
Wont drain or rinse
this may be of some help
4. WASHING MACHINE REPAIR GUIDE
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/washing-machine-washer-dryer/2967-washing-machine-a-washer-dryer-top-problems-a-common-cures
5. FIVE MOST COMMON PROBLEMS WITH A WASHING MACHINE
https://www.youtube.com/watch?v=-4j8RoesBrg
or go to my tip for more help re washing machines
good luck
Nov 23, 2016 | Washing Machines
Methods how to do white washing on pine wood?
First use a stain blocking primer such as Killz. If it is an item that is outside use a good exterior paint two coats. Inside items use interior paint two coats. Don't use exterior paint inside cause it can contain pesticides that can cause harm to you. Pine will seep sap for a few years so you may need to repaint sooner than usual.
Oct 25, 2016 | Washing Machines
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Service light on and just wants to drain, program wont reset.
It would help if you had included the make and model number.
There are many help videos on youtube about washing machines.
I think you are saying that the machine won't drain?
Check out this link to see if maybe your machine is here.
washing machine won drain YouTube
Oct 03, 2014 | Washing Machines
Simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 22, 2014 | Simpson Washing Machines
WASHING MACHINE WONT DRAIN
1. check the drain knob if operational or functional. 2. remove the water and check the drain inside of your washing machine if something block it or dirt, like hair, or other small particles and if positive clean or remove it. 3. check also the filter if has then clean it also. 4.check outlet solenoid valve if has, maybe its defective and this is subject for replacement. 5.check the hose pipe drain if possible plug out to the washing machine, check it if clean or dent.
Feb 13, 2011 | Washing Machines
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine wont spin and only drains when it wants to
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Jun 19, 2009 | Washing Machines
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
173 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
