Question about Falcon Exceed Rc 40 Rc Helicopter Replacement Parts: 50H01 33 Screw Set
Can i recharge the battery while it is still mounted in the copter or does it need to be removed? what is the normal charging time for the battery?
  • j4boxers Jul 13, 2009
    emissions
    do you know about the simulator e-sky? i have tried to load this software but keep receiving a message at the end saying not installed
    thanks again boxers
    Top Expert:
  • Falcon Master
  • 79,077 Answers
BATTERY CHARGE TIME IS ABOUT 3 1/2 HOURS, THAT IS FOR A FULLY DISCHARGED BATTERY
YES THE BATTERY CAN BE CHARGED IN THE HELO, JUST DISCONNECT THE BATTERY CONNECTOR AND PLUG THE CHARGER INTO THE BATTERY CONNECTOR, NO NEED TO REMOVE THE BATTERY..
Posted on Jul 13, 2009
  • yadayada
    yadayada Jul 13, 2009
    am not familiar with this software installation, do they have a support web site? that is where I would go.
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
My hercules doesnt lift. rotors turn but it spins counter clockwise uncontrollably.
i am really glad that this isnt a REAL helecopter. if you got it for christmas, you might want to return it- that is, after you verify that it is FULLY charged. this sounds like a half charged battery, that isnt spinning the bigger blades as fast as it should.
this could also be caused by any obstructions to the blades ability to rotate freely, something stuck to the blades- adding weight, bent blades, or internal belt/gear issues, regarding regulating the main blades, and the rear stabilizing blades timings.
if, before the charge, the dying battery caused the copter to crash, a blade could easily be bent, or have mud or something on it, weighing it down.
if the copter really is indestructable, i would go right back to a bad battery.
if the rechargeable battery got a memory after 4 days, i feel bad for you and your kids.
Dec 29, 2014 | Hercules Unbreakable Radio - controlled...
We haven't used the helicopter in awhile and we have forgot how to charge it, were should all the switches be ?
Are there electrical contacts on the bottom of the helicopter?
See if there is a place on the remote where you can attach the copter. Use the remotes' batteries to charge the copters' built-in, non removable battery.
Also... Google.
Jul 08, 2014 | Night Hunter Xtreme Glow In The Dark RC...
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
S107 charger light stays red all the time, doesn't change to green.
Check the batteries are new or in good condition. Also charging time is approx. 30 mins check in the manual how long charge time is. We also have replacement USB mini chargers available.
Kind regards, Julian.
rccontrolfreak.co.uk
Dec 05, 2013 | SYMA Toys industrial New Syma S107 Radio...
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
Not getting altitude
Use only alkaline batteries, rechargeable batteries do not have sufficient voltage to fully charge the heli.
Apr 05, 2011 | RC Micro X Copter Mini RC Helicopter
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
Falcon Exceed Rc  40 Rc Helicopter Replacement Parts: 50H01 33 Screw Set Logo
48 people viewed this question
Top Falcon Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Falcon Toy Expert? Answer questions, earn points and help others
