Question about Samsung Digimax S630 Digital Camera
Feather-like object on the screen
There is a feather looking object located on the left side of the screen and I can't remove it. I have tried everything. How do I remove this?
  • 75 Answers
Re: Feather-like object on the screen
You may adjsut the contrast or brightness setting of the camera or you may send in your camera to service center.
Posted on Nov 30, 2007
0 characters
3 Points
When looking througth my view finder, I see an object at the bottom left side which appear to be a arrow pointing up at a slight angle. What could it be?
If it's the icon in the bottom left of this diagram:
Then that means that there's no memory card in the camera.
Mar 07, 2011 | Nikon D5000 Digital Camera
The display look blank/black, I can not see the object via the display
Hi there press the display button on back side the camera. After that if the screen not displayed then you need to replace the Screen. Because thats damaged.
Feb 14, 2011 | Kodak EasyShare M1033 Digital Camera
I have 'card protect' acros the LCD screen of vivitar 8018, how do I remove this
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Apr 12, 2010 | Vivitar ViviCam 8018 Digital Camera
I tried taking pictures and a message comes up on the screen "write protect". What is wrong?
That usually means the slide switch on the side of the card is in the locked position.
Sep 10, 2009 | General Electric A735 Digital Camera
PowershotSD750 Focus More
Press the left mode-wheel (the side with the flower and mountain icon) until you see the flower (macro) icon in your screen. You're now set to focus on close-in objects, such as type. When you want to switch back, press the left side of the mode wheel once more until you see the mountain icon. You're now set to focus on more distant objects.
May 17, 2009 | Canon PowerShot A75 Digital Camera
Screens for the Z1275 can be found on Ebay for as little as $20 w/shipping. The rear case of the camera is held in place with 5 screws, one of which is under the left side panel (looking from the rear). Make sure the battery and SD card are removed before starting. Remove the right side panel by removing the two black screws and by opening the battery door it will help give you access to lift it away. Remove one chrome screw on the bottom back and one black screw the bottom left holding the left side panel in place. Slide the left side panel downward and remove the last screw underneath. The rear case is now held in place by several snap-fit points around the edge. Using a small nylon pry tool, strong fingernail, or a small flat screwdriver, work your way around the case and carefully pry the sides and bottom enough to release the rear case. Once the back is removed you can release the LCD from its frame by gently prying the frame around the LCD and lifting it up to gain access to the ribbon cables attaching it to the circuit board. The larger cable is held in place by a locking bar on the socket that has to be lifted to release it. Using care not to break it, pry the bar up so that it pivots 90 degrees. The smaller cable uses a slider that can be released by pushing the two tabs on either side of the socket toward the cable until it stops (only a millimeter or two). At this point the cables should slide out quite easily. Reverse the procedure to install the replacement LCD.
Aug 11, 2008 | Kodak EasyShare Z1275 Digital Camera
Cannon sd400 power shot
Sounds to me like you have a broken LCD screen. This is unfortunately very common in the SD200, SD300, and SD400 cameras. Because an LCD display is made up of a few sheets of very thin glass, they tend to break rather easil and then the "dye" leaks out, hence your feather pattern.
If you feel up to taking your camera apart, you can purchase a replacement screen on eBay for around $60-$80. If you don't feel up to trying to replace it yourself there are people on eBay who offer repair services for broken LCDs and they typically charge between $80-$100.
Apr 10, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Samsung Digimax S630 Digital Camera Logo
49 people viewed this question
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
