Question about Dryers
Loud noise Experiencing very load noise from spin dryer. Have replaced bearing accessible from rear of machine, hardly any difference. Louder in one drum direction than the other. Appears to come from area of motor. I have removed side panel and plastic cover over left hand fan. wonder if noise could be from motor shaft catching on remaining cowling underneath. Thought I might cut cowling slightly around shaft as it does appear to be a bit close. Problem is deep rumbling noise (non metallic).
    President:
  • 704 Answers
Sounds as though it could be one of the motor shaft bearings is worn or wearing, or might be working its' way out of the end housing it was pressed into. The best way to verify it is the motor bearing is to remove the belt drive from the motor pully and operate the dryer while you listen for the sound, if still there, you've isolated the noise to the motor and can explore further to see what exactly is causing the problem.
If that isn't it, please provide the brand and model number so we can zero in on the probable issue.
Posted on Jul 13, 2009
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 12, 2014 | LG WM-1832C Front Load Washer
Whirlpool Front load washer - wfw9400sw01. Sounds very loud during the spin cycle. Suspect a bearing issue. I have pulled the back plate off. Pulley, belt, shocks and motor all appear to be fine. What...
A loud rumble noise during the spin cycle is a good indication that the bearings have failed. The bearings are located in the rear outer tub. See link http://www.appliancepartspros.com/part_details.aspx?part_id=4426951 There are actually two bearings an inner and an outer bearing plus a seal. Water must have leaked past the seal causing the inner bearings to corrode. Once they start to rust, it just gets louder and louder. You are correct that Whirlpool does not sell the bearings and seal separately, but you must buy a new rear outer tub currently the price is over $400.
I had it happen to a different brand of front load washer and was faced to either, replace the rear outer tub, junk it or figure out how to replace the seal and bearing. I opted for the last and did some research on finding replacement bearings and seals. I had to tear the washer apart to get the bearings, then pound out the old ones to replace with new ones. It been working find for the last 2.5 year so far.
I found a website that might help you locate bearings and seals for your machine. http://www.hometask.com/washerrepair.aspx The site has a video on how to tear down your machine and shows you how to remove and replace the bearings. He might have the ones that you need on his site. Hope this helps you.
Apr 25, 2011 | Whirlpool WFW9400S
Maytag washing mchine makes a loud noise when on spin.
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.
Mar 29, 2010 | Maytag Washing Machines
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Crosley washing machine cw6000
I WOULD RECKEN WHAT YOU HEARD WAS THE BEARINGS IN THE MOTOR GOING AND WHEN YOU TURNED IT ON AGAIN IT SEIZED THATS WHY THERE WAS A BURNING SMELL JUST REPLACE MOTOR
Apr 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
69 people viewed this question
Top Dryers Experts
