Question about Nikon Speedlight SB-800 TTL Flash
D300, SB-800 fires but no exposure.
I shot a wedding last week... all of a sudden, in the middle of the ring exchange, I noticed my images had no exposure - my display was showing me an almost black image. I wanted to panic. What did I do wrong? I was in manual mode, and my D300 was not indicating an F/stop on the top display. I quickly checked everything but could not find anything wrong. I powered off/on camera & nothing. I then dismounted the SB800 & things went back to normal. Hmm...
I was using a Quantum Turbo Battery power pack for the SB-800. Can this have anything to do with this problem? Today I looked at the image info of several images I took with & w/out the power pack. W/out the power pack the data appears normal & images taken w/the battery pack show abnormal settings, to include, Focal Length 0 mm, and F-Number F/0. I was also using a Tamron 17-50mm F/2.8 XR Di II LD Aspherical (IF) lens. (Can't afford the Nikon version, yet).
Image info on shots that turned out ok, using the power pack & the 17-50mm also showed some strange stuff; Focal length: 5mm, F-Number: F/95. Is this normal? Is my lens giving it incorrect data? The flash did fire each time I pressed the shutter release. I didn't even notice a sync problem, although one would think so. Help! What am I doing wrong? or is this equipment incompatability?
  • n4ldg Jul 15, 2009
    Well... It appears that the puzzle is solved. It's the Tamron 17-50mm Lens. It has a problem communicating with the camera. I called Tamron, and explained the problem and gave them the image info for several images I shot with that lens, to include the blacked-out ones. The tech said it was a communications defect between the lens talking to the camera. Tamron has a 6 year warrantee for their lenses. So the repair will be free. Before I send it in, I plan on conducting a few more test shots with some settings that could possibaly be a contributor to this issue. Stay tuned.
    So, the Quantum battery pack is not the issue, as it does well with other lenses. Also the flash still requires 4 - AA, to run the computer in the flash. When the the Quantum battery pack is connected to the High Voltage connector in front of the SB-800, it takes over the charging of the capasitors. The flash switches the AA batteries to run the computer only. - Louis
  • 37 Answers
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Posted on Jul 14, 2009
  • Larz Jul 15, 2009
    Wow, that is odd, but I am glad you got it arrowed down.
    Sorry my info was not correct.
Intermittent dark images
Sounds like they are a little out of sync. Try adjusting the timer settings.
May 06, 2012 | Nikon Speedlight SB-800 TTL Flash
Are the sb-900 and the sb-800 heads the same? I have a sb-800 and I want to buy teh coco ring flash with the sb-900 adapter, are both the same, will it fit the sb-800?
No it is not the same. the SB 900 is 25% bigger.
I just got a Coco ring for my SB 800 (I bougth the one for the SB 900) and it is big. But I just filled the empty space with hard foam and works wonders. I can post a photo if you want.
By the way I have a D 700. It migth fit different in other cameras.
Jan 13, 2011 | Nikon Coco Ring Flash Adapter(49368824316)...
Shooting with a Nikon zoom such as 18-200 with a Nikon SB800 flash on a Nikon D300 body. I make an exposure of a person and the result is exceptable and then I zoom to the whole group of five people and it...
Depends on the zoom length. If you check exposure at zoom 18 mm then zoom to (lets say) 100 for the final picture the flash will zoom concentrating the flash power as well; the flash gets stronger. This is all explained in the SB-800 manual. On a zoom such as the 18-200 the more you zoom the smaller the f/stop. You are better off with a zoom that maintains its f/stop through the entire zoom range. That way when you check exposure at 18 mm lets say f/2.8 then zoom in it will maintain the same f/stop. Myself I am not a big fan of zooms especially ones when zoomed change to a smaller f/stop.
Aug 05, 2010 | Nikon Speedlight SB-800 TTL Flash
Will give correct expoures in ttl
Hard to tell what might be going on without knowing what camera you are using or what shooting mode the camera is in.
What I do is set my camera to Manual. Then set the shutter speed for 1/60th a second. Try a shot with the SB-800 attached - firing directly at a subject that is about 6 feet away and check your image.
To expand the range of the flash, you can change the ISO setting. Adjusting from ISO 200 to 800 will allow you to expose more background. Depending on the camera you are using, this may also introduce more noise in the image.
Mar 22, 2010 | Nikon Speedlight SB-800 TTL Flash
SB-800 -3EV message after about 50 shots or so
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
How to set up a photograph of a home interior so that exposure of indoor room features closely matches exposure of outdoors as seen through the window. Am using D300 and D2X with three SB-800 flash units....
Some cameras have a slower shutter speed setting that will give you this affect. A tripod will be needed as shooting at slower speeds can cause blur from a shaky hand.
Nov 12, 2008 | Nikon Cameras
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb-800 Nikon
Try Weld Bond to glue those back.
atdlee@netzero.com
Jan 05, 2008 | Nikon Speedlight SB-800 TTL Flash
Fried Unit
Mixing the batteries should not have damaged the flash. More likely the smoke came from the odd battery.
Aug 09, 2006 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
666 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
