Question about Panasonic Televison & Video
I have a PT-50LCX64 and when I turn it on it only stays on for a min.or 2 and goes back on stand by
  • 10,594 Answers
Have you replaced Lamp in TV?
Symptom shows TV need new Lamp.
Posted on Jul 13, 2009
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
Have apanasonic tv model # pt-50lcx64 it turns off within 15 min.
try to turn off sleep mode or adjust sleep mode timer
Jun 25, 2011 | Televison & Video
WOULD LIKE TO GET A WIRING DIAGRAM SO I CAN FIND OUT THE PART NUMBER FOR A CERTAIN WIRE THAT IS BROKEN. THE MODEL NUMBER IS: pt-50LCX64. THANK YOU
You can purchase one for $12.95 from the link below:
http://service-manuals-schematics.com/purchase.php?id=Panasonic+PT-50LCX64+Service+Manual+%2F+Schematics
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
Air filter need service and tv shuts off after 1 min. I have attempted to clean all the dust from the tv by removing the rear cover and using shop air to clean. I am wondering wether this is going to be...
I have the same problem with my 50" panasonic PT-50LCX64 tv. I have a call into a technician to see if it is going to be a cost effective repair, I am very unhappy with their technical support. I also have removed the bace and cleaned everything back there and blew it out. Their techs. say it is an internal filter that has to be cleaned by a service center or dealer. They will not say where the filter is at so I can clean it myself.
Feb 05, 2011 | Panasonic PT-50LC14 50" Rear Projection...
When i turn on the TV...it runs for 5-10 min...then shuts off... this turn it back on...it runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
