Question about Royal Office Equipment & Supplies
I have something caught that looks silver and i can't get it out. can i take the top off
  • tecamper Jul 13, 2009
    The model is the SC180MX by Royal.
  • 3,037 Answers
You should be able to, but since you didn't post a model number I can't be sure. Usually there are some screws that will easily remove the cover on these. Just be aware of where any parts go that you may accidentally take off in getting to this piece.
Benjamin
Posted on Jul 13, 2009
  • Benjamin Patri
    Benjamin Patri Jul 13, 2009
    yeah, the top should come off with the model number you gave me
I have 1991 Lebaronconvertable. Top goes down ok but lacks about 2 inches from closing, can't close by pulling down. Hydraulic fluid?
Well, if it were me, I'd open up enough covers to get a good look at the mechanism and then watch it in motion. I would guess something is binding on something else close to the end of the travel. You're just going to have to get in there and take a look. If you're not happy doing that, get someone who is. I don't think hydraulic fluid (lack of) is your problem. More likely something is caught close to the end of closing.
Jul 10, 2017 | Cars & Trucks
I have a problem with sewing, the stitches on the top are tight and the bottom stitches look fine, when I sew the material is bunched up.
The bobbin thread is too tight it's either getting caught on something or tension of bobbin needs adjusted
Mar 05, 2015 | Sewing Machines
How do I get rid of high pitched whistle in cabin air system?
blower motor might be going out. worn out bearings.
Jun 28, 2014 | 1998 Toyota Camry
Sound when it spins that sounds litle bearings
Check for something caught in the inner bowl. Check with torch if something caught between inner & outer bowl. Check main bearing, main bearing noise is usally associate with leaking water.
Dec 19, 2013 | Haier HLP21E Top Load Washer
Won't spin or drain water
Something may be caught in fan that cools te motor. Tilt unit back and look for white fan blades. Is somjething caught in it? /
Sep 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Tiger shark has bubbles coming out of top but will not move
Something is caught in the tracks that make it move. Look under the blue track that move it. I had the same problem and found a rubber swim mask headband all caught in the tracks. I had to take the side panel off...6 screws on the inside you can see when you take the filter out and removed it and now it works fine.
Jul 15, 2009 | Aqua Vac Tiger Shark
I press the foot pedal the needle does not go up or down.
The bobbin winder on the top of the machine might need to be pushed the other way . It could be in the winding position. hope this helps
Jun 06, 2009 | Singer 3116 Simple
Maytag washer top load
hi thanks for the question i think you could have a problem with your tub bearing or you could have a piece of clothing caught between the tank and tub remove the front lift up the top remove the plastic top and look you will see if you have something caught in the space between those two pieces thanks the appliance doc
Sep 24, 2008 | Maytag PAV2300 Top Load Washer
Could something be caught? Instead of the bearing being seized?
sorry marisa sounds like a bad rear bearing. but you can remove top .bottom and rear panel use a bright light to look thru the outer tub. for something stuck...
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
18 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
