Question about Tilia FoodSaver V2240
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
  • 308 Answers
The function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Posted on Jul 13, 2009
My foodsaver does not heat up to make the seal.
Did it ever work? Try another receptacle and if that doesn't make a difference you probably need a replacement.
Aug 02, 2017 | FoodSaver Kitchen Appliances - Others
Why my foos saver is not sealing
I've found with mine I have to hold down firmly on the top while unit is heating the bag to seal it. I continue to hold the lid down for about 10 seconds after heating stops until the seal cools. Hope this helps.
Sep 09, 2014 | FoodSaver Smart Seal Vacuum Sealer V3825
Need to replace the heat stripe tape on my tilla foodsaver vaccum sealer
concerning my food sealer: the strip under the heating wire came loose & would not stay in place. i almost threw the unit away but its at least $40 to buy another. i decided to buy a roll of PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape. PTFE is Teflon but u cant use Teflon as a search term because of the copyright. i found a roll on ebay for $3 (free ship) from China (how do they do that!). it took about 2 weeks for the roll to arrive. I cut a strip to fit under the wire. The wire had burned & partially buried itself in the unprotected plastic. Be gentle when nudging it out & clean off any material that has attached itself to the wire. Seals & works like new!
would you like to buy the rest of the roll? the roll has about 28 feet left.
Dec 27, 2012 | Kitchen Appliances - Others
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver vac800 not sealing bags any way to fix heat strip?
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Sep 16, 2010 | Tilia Foodsaver V835 Vacuum Sealer
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
May 17, 2010 | Tilia FoodSaver V2240
My food saverf V 835 just stopped sealing. I haven't used it that much, and it worked fine last time I used it.
I just spoke to customer service. I was told there is no replacement part for the heating element. They did offer me a discount on a new Foodsaver.
Feb 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Tilia FoodSaver V2240 Logo
397 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
