Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
Just showed up a 2" white bar with a green line on left side of screen, with or with a signal
  • 304 Answers
You have one or two possible problems. First you might have a bad Buffer bd and second a bad Plasma Panel. Have a trained Samsung troubleshoot the problem.
Posted on Jul 16, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Red lines on Samsung UN46B7100. Is this the TCON board or the panel?
Have you checked all cables first? Color fluctuations and problems of this nature can be caused by a bad VGA/HDMI/Component cable. Try plugging your source device into other inputs and see if you get the same result. If that happens you more than likely have a bad video card.
Aug 31, 2012 | Samsung UN46B7100 45.9 in. LCD TV
Jayco camper has 6-plug connector------car has flat 4-plug connector where do green,yellow,brown and white wires from car flat 4-plug connector connect to on yellow, blue,brown,red,green and white wires...
It would be easiest, and best, if you were to upgrade the cars' trailer connector. The 4 way just supplies brake, parking, turnsignal, and a ground. The colors are the same on the 6 way, but 2 lines are added, usually for a electric brake controller and aux. circuit. Be careful about using the battery line (Red) on the 6 way connector unless you are also upgrading the white wire to a heavier gauge (at least the same size as red).
Green - Stop and Right Turn Signal (4/5/6/7 way)
Yellow - Stop and Left Turn Signal (4/5/6/7 way)
Brown - Running Lights (tail, side, tag) (4/5/6/7 way)
White - Ground / Negative (4/5/6/7)
Blue - Electric Brakes (5/6/7 way)
Red - Aux. charge line for emergency break away, battery charger, etc. (7 way)
Purple - Aux. backup lights / other purpose (7 way)
Aug 16, 2010 | Electronics - Others
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
