Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Curious Did you try any of the recommended solutions? I'm having the same problem. Does your TV come on at all? Mine will not...when I power it up it makes a few clicking sounds like it wants to come on, the LAMP light blinks a few times, then just the bright green LAMP light. I'm thinking my new lamp is bad or the lamp ballast needs replacing. Not sure.
  • 304 Answers
It is best to replace the Lamp and Ballast at the same time because if you only replace one or the other, the part you did not replace might reverse damage the new part. Locate the Lamp Door on the rear of the set and remove it. You will see a Lamp Module inside with a Handle. Loosen the two screws and remove the Lamp. DO NOT TOUCH THE FRONT GLASS AT ALL!!!. If you see shattered glass inside, then you have a bad Lamp. Look on the Left side of the set and you will see a Orange sticker labeled Lamp Code. Record that code and purchase a Lamp and Ballast. There are a number of Lamps and Ballast listed for this tv so the Lamp code is important when ordering from online merchants or you have a trained Samsung tech take care of this for you. 1-800-Samsung can give information on the best shop to call locally that they trust.
Posted on Jul 16, 2009
My tv wont turn on how do I fix it
Thanks for the video. There is not much that be done, other than taking it in for repair. Are you comfortable with removing the back casing and replacing parts? Just curious. If you've tried powering with the remote and the button on the TV, with no success, then something inside is fried. Considering the side of the TV (not flat panel) it's likely that dust/dirt has accumulated on the relays/connectors. If you do and are able to remove the back panel, I would recommend cleaning them with a suction vacuum (hose attachment). That is part of what a TV repair shop would do. I am guessing that you've already checked your homes fuse box and tried plugging your TV into a known working outlet. Good luck!
Nov 30, 2012 | Televison & Video
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
I am having trouble with the tuner on my Olevia 26" lcd. Where can you buy replacement av input modules?
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Nov 10, 2009 | Televison & Video
The tuner's not working and won't let add channels.
no channels? blue screen? no signal?
Solution:
A Converter hdtv box... is the SOLUTION!!! try it..youll see!!!
Olevia tv fixed!!!
Oct 19, 2009 | Syntax Olevia 527-S11 Television
Same issue - Hitachi Plasma
do you know what board they said it was ..mine is =doing the same thing as well after a power surge
Oct 26, 2008 | Hitachi 42HDS69 42 in. Plasma Television
RCA R52WH74 Convergence Problem
No my brother and I have been doing television repair since the mid seventies, and when we retired we decided that we would start a business as a way to help the avererage person repair their own sets without having to pay alot of hard earned money for something they could easially do theirselves, that why we give free tech support, 99.9% have easially repaired their sets for less than most shops charge for the estimate.
Sep 11, 2008 | RCA R52WH73 Projection Television
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
Blank screen
I repaired mine. It had the same problem. Could be power supply. If you open it then maybe I can help.
Nov 30, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
61HX70 61in. terribly distorted picture blinking red power light
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Oct 22, 2007 | Toshiba 61HX70 61" Rear Projection...
Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Apr 12, 2007 | Polaroid FLM-2011 Television
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
Jerry Greenberg
Jerry Greenberg
