Question about Acer Aspire 5100-3357 Notebook
The media drive is not recognized in the system bios or windows xp device manager.
  • 358 Answers
Try this quick fix :
Get a screw driver and trace the screw holding the Media Drive to your system at the back of your laptop, then unscrew it and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you. Then clean the interface connecting the drive to your laptop.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on your system again and check it in the system BIOS if its now detected.
If it doesn't work after this, then I'm afraid you might have to get another drive.
Hope this helps you out.
Posted on Jul 13, 2009
Windows Xp not recognise my USB TS4GJF110
To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
Aug 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
XP not recognizing 5th SATA drive in new motherboard
Since you are a experienced PC user, I will cut down to the chase as I might have a idea what your problem might be. I tried to find more into on your issue but couldn't source anthing of importance:
It might be that your last SATA port that you have connected your hard drive is different from all the remaining 5 - Meaning it is set up differently BY DEFAULT in the BIOS. FOr example it might be set up to be on a certain "RAID" setting or mode that might prevent it from being seen within Windows XP.
What I am trying to get at is that maybe that last drive "mirrors" another drive by default.
Please try also to download the latest BIOS for you mainboard, and make sure all hard drives in the BIOS have the same setting on them individually. Spefically, check your RAID and AHCI settings, boot up lineup and other settings that might influence this.
Also check if your new hard drive isn't faulty, since it picks up in BIOS but not in device manager - The drive might have a plate fault or a read/write head issue. This might explain why it is visible in both the BIOS AND the device manager under "Hardware devices" but not in the "Disk Manager/Management".
As you know how to format and partition a drive, i do not need to query if the drive as been initialized, since you already have set up the other 4 hard drives without a problem.
May 24, 2010 | Microsoft Windows XP Professional
SATA / Optical Drive Not Recognized
In my travels through this nightmare called Windows, there have been some real issues. I ran into this same problem with XP with SP3, What I did was set up a virtual machine running Vista Premium and loaded the SATA Optical with the Vista OS which recognized it right off. I was able to use the drive just fine when using the Vista in the virtual machine but was not seen in XP. Have not found a decent work around this....just waiting for Windows 7 to come out so I dump both XP and Vista and start over learning another new curb, but at least I've been told that a huge amount of drivers are to be loaded into the new OS...we'll see.
Sep 18, 2009 | Intel Computers & Internet
Ntbackup does not recognizing the media
go to services restart removable storage service
go to device manager > disable and enable the tape drive.
Hope this helps
Siju.D
Jun 20, 2009 | Dell PowerVault 114T (0CC011) LTO-3 Tape...
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Disk drives not recognized
Check device manager and see if its showing a conflict.If so you will need to click Start -> Run, type Regedit
1. Remove the Upperfilters and Lowerfilters values completely from the following registry key (Windows 2k/XP):
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
2. Restart your computer.
This worked for me and CD's work again.
Dec 25, 2008 | Microsoft Windows XP Home Edition
My daughter has a kingston 4GB DTI Data traveler. When she tries to put mp3 or any type of files it gives her a message that the file path can not be found and can not copy anything to the jump drive..She...
insert your pen drive again and see whether your system recognize it. go to my computer and right click on the pendrive icon and select format , then clink ok.
Jun 19, 2008 | Computers & Internet
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
HDD not recognized in XP Installation
if you are using it as a slave hard drive, you should be able to right click my computer, manage, then in next window double click storage, then disk management, then look for your drive, you can then look to see if its recognised, if not it will tell you that its not configured, and you should be able to right click on it and format it.
Jun 07, 2007 | Maxtor DiamondMax 10 300 GB Hard Drive
Acer Aspire 5100-3357 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
