Question about Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT Conventional Monitor
Retrace line on monitor
My Sony CDE E540 flickers several times during bootup and retrace lines can be seen on the screen. If I set the brightness and contrast to 40 and 40 the screen is gray. right noe the contrast is at 85 and the brightness is at 12, Need help
Steve
  • SCaldwell Nov 20, 2007
    Thanks for the help,
    I'm an electronic engineer working for Bose Corp. I look for all the obvious first, cold solder like you mentioned and went ahead and sweated all the joints on the yoke and the fly back transformer, adjusted the brightness on the fly back and the problem still presists, got a schematic for it and narrowed it to the vertical control section but not sure which cap in the IC003's control is causing it.
  • 749 Answers
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Posted on Nov 17, 2007
  • Rommel Balcita Nov 17, 2007
    adjust the main brightness control while your monitor is on! adjust it to a point where the retrace lines are gone!
    if you have no experience yet with electronic servicing then you should seek help to a qualified technician or send your monitor on a repair shop. they should not ask you for big payment since it wasn't totally damaged or broken yet.
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
I have green arched =lines r=going through my screen How do I fix this?
If the lines are slanted up from left to right and spaced several inches apart, you are seeing the vertical retrace line. In that case, you may want to turn down the screen voltage on the green CRT. The instructions for making this adjustment are given in the service manual.
It should take just a small tweak to hide the retrace line. If adjusting the screen voltage won't do the job, check for a leaky or improperly biased CRT driver transistor, then compare the video waveforms with one of the other CRTs to make sure the voltage at the vertical blanking interval is correct.
In the worst case, there is a problem with the CRT. This is generally accompanied by occasional arcing (bright green flash or the set shuts down with an error code flashing on the power light).
Dec 05, 2010 | Sony KP-51WS500 51" Rear Projection...
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
May 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Switches off after 3 to 4 secs--little bright screen hor line and small retrace lines
On the my sony website, they said try unplugging the set for 3 or 6 minutes. Then plug it directly to the wall. If that don't work, and it won't; seek a service center. I have the same problem.
Next time we better buy Panasonic. Sony products fail ALOT. I had a 5 disc DVD Changer and it was defective and it was part of a class action lawsuit,
I believe this is the same sort of problem.
The sony Vaio laptop computer gets consistent poor reviews.
I brought an alarm clock and its back up battery never worked right out of the box.
I brought a cordless phone and the LCD display went blank.
I am so DONE with Sony.
Good name; Bad products.
Aug 23, 2008 | Sony KV-24FV12 24" TV
21PT3324/71 Philips TV wont stay on
Try this: On the flyback transformer, raise the SCREEN voltage. There are 2 controld on the flyback - the top one is FOCUS and the bottom one is SCREEN. As the tube ages its emission decreases, and the computer monitors the tube's emission. When the emission gets to be too low, the computer shuts the set down. This is exactly like IK blanking in Sony sets, except Sony blanks the video and Philips shuts the set off. To set the screen voltage properly, turn the brightness and contrast to 0, raise the screen voltage until you see the white retrace lines in the picture, and then back down on the screen voltage until just past the point where the retrace lines are gone. Reset your brightness and contrast and the set should play fine.
Aug 13, 2007 | Philips 20PT6441 20" TV
Screen
are the line bright white retrace lines going down screen? If so then screen voltage maybe too high
May 19, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KP-46S25
A "Gray Scale" adjustment may solve you problem. If one of the picture tubes is set too high it will cause these RETRACE lines. Then too a weak picture tube might cause this. If the horizontal lines are one color: red, green,or blue then whichever color that is shown would tell you which tube is set too high. Your set has 3 screen controls that control the brightness of each tube. One may need to be turned down a little. Stargazer
Mar 11, 2007 | Sony KP-46S25 TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT Conventional Monitor Logo
153 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
