Question about Microsoft Visual Basic .NET Standard 2003 for PC
Control that implements a expandable/collapsible
Using a SQL VIEW as a DataSource, I want a
Control that implements a expandable/collapsible datagridview in VB.NET .
Similar to ACCESS's Data-Access-Page where the Row info is grouped
and preceded with a ''+'' sign when contracted and preceded with a ''-''
sign when expanded.
  • 3 Answers
SOURCE: Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Posted on Jul 17, 2008
SOURCE: Microsoft Access query in VB
first you need to create a record set to do this, after creating a record set RS1. please follow the code below:
Update the code as per your requirement.
Rs1.Open "Select * from table_name where UserName = '" & UName & "'", Cn1, adOpenDynamic, adLockOptimistic
Posted on Mar 17, 2009
kd24911
  • 90 Answers
SOURCE: how do i use date in visual basic 6
I am not getting your problem clearly.
If you are referring to save the input dates as date in database with the help of sql query then you need to provide hash(#) mark at the beginning and end of date values. It will resolve your problem.
Hope this helps and let me know if you are not getting the solution clearly.
Thanks.
Posted on Mar 18, 2009
Instant Help
  • 73 Answers
SOURCE: I need a Vb code for making Graphs using MS Access
Dear, you can check the following web page for the optimum solution to your problem.
http://vbcity.com/forums/faq.asp?fid=7&cat=MS+Chart+Control
Best regards.
Posted on May 25, 2009
  • 11 Answers
SOURCE: free visual basic source code salary database sample
you solution is her
Building Websites with VB.NET and DotNetNuke 4/by Daniel N. Egan (Author), Steve Valenzuela (Author), Michael Washington (Author)
Description
DotNetNuke is an open-source Content Management System and web application framework. DotNetNuke has taken the Microsoft world by storm and now at version 4, its community has grown to over 200,000 users. This book covers virtually everything you need to know to get your DotNetNuke website up and running. Concisely written and with clear explanations, this book is covers installation, administration, deployment, site creation and all of the basic built in DotNetNuke modules. For developers, chapters on the core architecture, skinning and custom modules, including coverage of the DAL+, give you the skills to customize and extend your site. The book starts off by giving you a deep understanding of working with basic DotNetNuke sites, guiding you through the features and giving you the confidence to create and manage your site. After that, you will journey to the heart of DotNetNuke, and learn about its core architecture. Always concise, relevant and practical, you will find out what makes DotNetNuke tick, and from there, you will be ready to customize DotNetNuke. Developers will enjoy the detailed walkthrough of creating a new custom modules. Special emphasis is given to the DAL+, an extended feature set of the DotNetNuke Data Access Layer (DAL). You will see how to create custom modules with the DAL+, and invigorate your module development. Web designers will enjoy the material on skinning, helping them to create a new look for their site. You will learn about creating new skins, and packaging them up for easy deployment. You will master all of this as you leap into the development of a DotNetNuke 4 site. This book will give you the skills to create and manage DotNetNuke websites as quickly as possible. You will:
* Install and configure DotNetNuke
* Master the standard modules
* Understand the core architecture of DotNetNuke
* Explore the inner workings of DotNetNuke modules
* Extend DotNetNuke using the DAL and DAL+ to create powerful custom modules
* Create your own skin using a HTML Editor
* Find out about where and how to host and deploy your site
You can use this book to help you set up and administer a DotNetNuke portal, even if you have a limited knowledge of ASP.NET. You will learn how to setup and administer an example site, stepping through all the tasks to ease your learning. If you are a developer, this book will help you extend the DotNetNuke portal by first helping you understand how the core framework works and then show you how to create custom modules and skins. A rudimentary knowledge of VB.NET programming is assumed, but the emphasis is not on becoming a better VB.NET programmer but on taming DotNetNuke. This book has been written for both the beginner wanting to set up a website and also ASP.NET developers with a grasp of VB.NET who want a deeper understanding of how to work with DotNetNuke. To work with the DotNetNuke code, you will need access to Visual Web Developer Express or Visual Studio .NET 2005. No prior knowledge of DotNetNuke is assumed.
download link:
http://w14.easy-share.com/1701584071.html
or:
http://dep
Posted on Jun 16, 2009
WHAT IS VB.NET?
Visual Basic .NET (VB.NET) is an object-oriented computer programming language that can be viewed as an evolution of Microsoft's Visual Basic (VB) which is generally implemented on the Microsoft .NET Framework. It is a competing technology to Sun's (now Oracle's) Java 2 Enterprise Edition framework.
Sep 15, 2010 | Computers & Internet
Developing an application with vb.net 2008 and i'm finding it
You need to set up an ODBC DSN and use this in your connection string then instantiate an ODBC connection. For example:
Dim MyConnectionString As String = "Driver={MySQLDSN};SERVER=localhost;DATABASE=MySQLDatabase;" '
Dim conn As New OdbcConnection(connectionString)
conn.Open()
Dim da As New OdbcDataAdapter("SELECT * FROM Customers", conn)
Dim ds As New DataSet()
da.Fill(ds, "Customers")
dataGrid1.DataSource = ds.DefaultViewManager
conn.Close()
Sep 04, 2009 | Microsoft Computers & Internet
Visual Basic and SQL
Visual Basic 6.0 and MS Sql server 7 or 2000 are highly compatible with each other. VB.net is compatable with sql 2005 which is inbuilt as well.
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
How get sql data backup
there is facility in enterprise manager to take back of database!
Feb 04, 2009 | Keystone Active Server Pages (ASP)/Visual...
I need to know how to connect vb.net with sql server
Try:
http://social.msdn.microsoft.com/Forums/en-US/vbgeneral/thread/47d81de1-e85b-4ee2-9d36-0ce45c23c59b/
http://social.msdn.microsoft.com/Forums/en-US/sqldataaccess/thread/728f71f5-6018-40f8-b6f5-b09523fa645e/
Or just search Microsoft's Knowledge base with Keywords of 'connect', 'vb.net', 'sql server', which is what I did to get above results.
Feb 02, 2009 | Computers & Internet
How to insert in to data base data throught using datagridview in vb net
Coolboarders 3 Go to tournament and type in "BIGHEADS" and the word "Cheater" will be spoken. Then you will be able to change the size of the boarders head by pressing [PAUSE] and hitting R2 or L2 to increase and decrease the head size.
Aug 16, 2008 | 989 Studios Cool Boarders 3 for...
How to connevt visual basic with oracle(sql)
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Jan 23, 2008 | Computers & Internet
Installing SQL server and VB.NET on VISTA Home Basic
installl SQL SERVER 2005
Vb.net is fine its your sql that will mess things up
BTW visual studio come with an SQL server
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Visual Basic .NET Standard 2003 for PC Logo
249 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
