Question about Jenn-Air JJW8230D Electric Double Oven
I have a jenn-air double oven that is level for cooking on the bottom but the top oven is not level. I can't find manuals on the oven. Is there an adjustment between the upper and the lower oven. Do you have pecturess that show how to adjust the overns?
    President:
  • 704 Answers
First check to determine if your cabinet face is plumb (level), as sometimes that is the problem. If the entire face of the cabinents are plumb on both side, you'll likely need to either shim the top edge of the upper oven section or remove the oven and readjust the leveling adjustments (or shim the rear of the upper oven assembly), depending on just how far off the oven is from being plumb and level.
I've tried searching for the installation manual for your oven and found three (3) possible model manuals that could be helpful. I've included the link to the Jenn-air site so you can look at each and glean which one would be the most helpful for your issue.
The link will show the owners manuals and installation instructions that should apply for your situation.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JJW8230D&siteCd=JA_EN_US
Posted on Jul 13, 2009
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
I have a Jenn Air ww2711w0 double oven. The Lower
Your t-stat or control board could be out on this unit. Can you check your t-stat and see if it's working alright? If it is, it's probably your board. Hope this helps~!
Aug 20, 2009 | Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Double convection oven doesn't cook at the same rate
NOT SURE ABOUT THIS UNIT , SOME OVEN UNITS HAVE A CALIBRATION PROCEDURE THIS MIGHT NEED TO BE CALIBRATED
Nov 26, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air Double Oven JDR 8895
http://www.maytag.com/support/manuals_literature.jsp first go here and download a new manuel if nothing you can fix reply to me and ill look in the service manuel ok
Jan 17, 2008 | Jenn-Air JJW8230D Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Jenn-Air JJW8230D Electric Double Oven Logo
145 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
