Question about Panasonic AG-MD830E S-VHS VCR
I have an AG-MD830 S-VHS player, the tape does not auto-feed into player, is it a sensor problem or mechanical issue?
    Champion:
  • 221 Answers
Most likely a mechanical problem. check the timing of the gears in the mechanism.
Posted on Jul 17, 2009
Magnavox vhs and dvd player vhs insertion issues
Someone is going to have to take the unit apart---mechanism issue with the tray or the gears that lower it etc---not too many shops left that work on VHS decks anymore so call around first.
Dec 03, 2012 | Televison & Video
Colour Noise and Dim Display
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Feb 19, 2008 | Panasonic AG-1980 S-VHS VCR
Have MAG TV model CT270MW8 27 inch that wont stay on unless a VHS tape is in and then only if VHS player ejects it (automatically) and then reiserts itself. The tape then/must stay in
You have a mechanism problem in the player---it has two sensors in the tray and they detect the tape is in and load it.
If the unit was working it will each time turned on cycle the mechanism to see that it functions--shutdown if not functioning correctly.
Apr 28, 2012 | Televison & Video
Ag-w1 mechanism
It may be a tape end sensor problem, kicks tapes back out.
Mar 25, 2012 | Panasonic AG-W1 VHS VCR
MD830 black and white playback only
hiya
the heads are dirty run a wet and dry head cleaner through it a couple of times that should do the trick the head cleaners can be bought at you local electrical outlet
hope this helps
John
Oct 26, 2011 | Panasonic AG-MD830E S-VHS VCR
VHS player ejects the adaptor
Please check to see it the battery on your adapter is worrking fine. Or else replace the battery . If mechanical type load up the tape before you load the cassette to the player. If this ejects again the adapter is not landing well into the mechansim. cleck within the tray for any foreign bits that is preventing the adapter from loading. Also if the end sensors are detecting , use a tape to cover the inner hole of the adapter. if the tape is tight in the adaptor- check for free state by turning with the finger.
If your regular tapes are playing well then you will get the fault without much of an issue but recheck on these tips. Helpful? good day
Jul 10, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Panasonic AG-1980 Wont load cassette
probably caused by the mechanism being mis-timed. re-timing isn't difficult, but a service manual is absolutely necessary.
Nov 16, 2008 | Panasonic AG-1980 S-VHS VCR
"End of Tape" message
It sounds to me that the sensor that senses the end of the tape is defect.
This is a tiny bright LED which you can easily overlook because it sometimes is fitted in a plastic frame.
Feb 21, 2008 | Panasonic AG-MD830E S-VHS VCR
Video tape stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Panasonic AG-1980
most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Sep 24, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-MD830E S-VHS VCR Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
