Question about Nikon D1H Set Digital Camera
Will not charge batt
Can not get it to charge
I am sure you ave figured out what to do for this poblem but if not...I had this problem with a nikon I just purchased. The guy I bought it from said it was the battery charger, so I purchased a battery charger on ebay-"new nikon d1 battery charger" was the actual listing and it cost about $40.00. You can get the actuall charger that comes with it on ebay- but it cost alot more money. I recieved the product, tried it on my battery (which was suppose to be new) and it still would not charge. I took all my stuff (battery, new charger, old charger) to a local battery shop in town and they tested it all for me. Come to find out it was not the charger all along, it was the "new" battery- UGHH! The whole point to this story is this- if you have not aken your battery and charger to a battery shop yet- do that first. Then go from there. Like I said- you canget the charger on ebay- and the battery can be bought for about $36.00 too. I would not recommend buying both like I did! Good luck.
Posted on Mar 26, 2008
Iforgot how to charge my batts
if all batt,are connected and are 12V you can charge from one and that will charge the rest in parrell ,even with a new batt hooked up
Sep 20, 2014 | Cars & Trucks
I have a Prosport 20 Plus that charged 3 new trolling batts It has worked fine for 2 yrs.I found that one batt was not charging and I replaced 3 burned out fuses.The blue,red and finally the green lites...
check the cables between the batteries, and consider changing the cables that run to and through the uncharged battery. Also make sure that the batteries are not cross connected (positive to a negative) and that there is no corrosion on posts and cable connectors. I had a similar problem.
Jul 27, 2017 | ProMariner Prosport 20 Plus Gen 2 Heavy...
Not charging replaced alternater still wont charge
Be sure to charge the battery, otherwise you might smoke the new alternator(not made to charge a dead batt.). Have the batt. load tested. Check batt. cable ends for corrosion.
Nov 11, 2010 | 1994 Plymouth Voyager
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Good batt & new alternator.. but battery keeps losing charge
Make sure all connections at alternator are attached. On some, the regulator is inside the computer and if bad, requires computer change.
Jun 26, 2009 | 1994 Jeep Grand Cherokee
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Why won't my charging light come on when I try to charge?
Try to leave it on charge for a 24 hrs. If the batt gets below a certain voltage the charger will not come up to fast charge rates(light on) to prevent damage to the batt. If it does not take a charge, it is possible that it is faulty. If you have been using the batt regularly and it suddenly stopped taking a charge, it may be the charger at fault. If you you have not used the batt for a while, it may be faulty. only way to really check for sure is to try a new batt. If you have any more questions about it, just ask away. Good luck
Aug 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
No charge
check the batt mayb your batt drained off... try using other batt.  if still doesnt work, probably you have a software or hardware failure...
but if it works w/ other batt try charging it, if still doesnt charge your phone charging section have a prob...
just visit your nearest service center to help you...
Oct 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Nikon D1H Set Digital Camera Logo
102 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
