Question about Goldstar KG6000R Window Air Conditioner
Sounds like when you put sneekers in a dryer?
    Scholar:
  • 91 Answers
Sounds as if one of the two fan blades is hitting the housing of the unit. May need to removeunit after unplugging and visually inspect squirell cage and outer fan blade. May need to resecure/ Good luck
Posted on Jul 13, 2009
Testimonial: "very helpful thanks,it was the plastic round thing was broken,bought new part and fixed it myself working great!!! thanks!! julie"
Dryer makes a screeching sound when run
It's probably caused by a coin, nail or screw between the dryer drum and the dryer housing. However strange it may sound, just put your head inside the dryer drum and look around the front juncture between the drum and dryer housing. You may find the offending object fairly easily.
Jan 25, 2015 | Washing Machines
Need assistance reinstalling the drivers on my Toshisa Laptop. I did a clean install (Win XP) and now the laptop does not have any drivers install. Additionally, I can not setup my Internet so that I can...
Get the Toshiba version of XP which will contain Toshiba specific drivers for your model. Download to a thumb drive on another computer then "sneeker net" the software to your Toshiba.
(((sneeker net ... = walk from computer A to your Toshiba ... in your sneekers)))
Aug 16, 2010 | Toshiba Computers & Internet
Kenmore elite, model 110 60952990,stopped working after I tried to dry a pair of sneekers. It doesn't do anything when the power butten is pushed. Thank you.
The thermal fuse (part number 3390719) is blown causing the motor not to run. This thermal fuse is located on the blower housing beside the thermistor (part number 8577274) and it is wired in series with the motor thereby cutting power to the motor when it fails. The failure of the thermal fuse is due the failed thermistor; these requires both the thermal fuse and the thermistor to be replace.
Access to the thermal fuse and the thermistor for replacement or testing requires the removal of the lower front access panel which is secured to the front panel by two retaining clips positioned about three inches away from the sides. Pry the clips to release it and remove the lower front access panel. The thermal fuse and the thermistor can now be accessed.
Using a volt-ohmmeter, check the continuity of the thermal fuse which is to the left of the thermistor. Replace the thermal fuse if it reads open together with the thermistor.
Remove the mounting screws and mount the new parts in place. Disconnect the wires from the old failed parts and connect it to the corresponding component. Reinstall the lower front access panel back into position.
Apr 22, 2010 | Kenmore 63942 Dryer
Carpet roller quit working after it try to vacuum my sneeker
The Dyson replacement part that you likely need has a Dyson part number 910348-01.
It's available at reputable vacuum cleaner shops or you can find it here. http://buyitnow64.stores.yahoo.net/dyvacldcrebe.html
Apr 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Put shoes in dryer and it stopped. When I turn it
Could be broken belt does drum turn freely by hand if so the belt gone
Mar 31, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Device Manager (Win XP Home) reports no Ehernet Controller, so I am unable to connect to Internet through my broadband/cable internet. It has been there before but not after a reformat and new loading...
I dont know where it went ... I can tell you how to get it fixed. You will need your sneeker net to work unless you happen to have the original software that came with your NIC (Network Interface Card). Have the software, put it in and load the driver per instructions you will get from the software.
If you dont have the software, (You will need to know what kind of NIC you have) go to the Manufacturers website, search your NIC and down load it the software. Move the software to a floppy (if appropirate) or to a CD and (with your sneekers on, ) jog on over to ... the other computer and follow the steps above.
On the ohter hand, since Windows XP is pretty good at PnP (Plug and Play) your NIC may be dead and in need of replacement. Before you replace it (please be sure to observe static electricity precautions) find and remove the nic and then replace it in the slot and try again. Be sure you unplug your computer before you do this also.
If yo need more help, post a note on this comment
Thanks for using FixYa.com
Positive comments welcome
a
Oct 29, 2009 | Computers & Internet
Bang, Bang, Bang. That is the sound my dryer
try taking yoga classes and put your dirty yoga clothing in the dryer and that should calm her (meaning your dryer) down.
May 06, 2009 | Dryers
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Creda hotpoint tumble dryer
sneekers or other heavy objects will do that.also your door catch mechanism is probably wore
Dec 30, 2007 | GE DBL333EA Electric Dryer
Goldstar KG6000R Window Air Conditioner Logo
76 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
