Hammering Logo
Brian Hall Posted on Oct 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Milwaukee demolition hammer when you pull the trigger it starts full rpm then with trigger still on slows right down anyone know what this might be thanks
Pieter Vleeshouwers
Level 3:
  • Master 2,029 Answers
  • Posted on Jan 02, 2016
Pieter Vleeshouwers
Master
Level 3:
Answers
2029
Questions
0
Helped
4112485
Points
7389
RPM magnet which is at the bottom of the electric armature seat is loose and fused in the lower bearing seat of the motor enclosure try to do this with a small screwdriver and make the surface smooth again from the motor housing where small witplastic magnet a very tight space free to rotate, order a new magnet BUT make sure he is glued with a good glue and dried before reassembeld Milwaukee has often into trouble here.
I'm pretty sure that you have a rotary hammer 500 S GOOD LUCK ! position 1236 MAGNETIC DISC (1) 4931426570 by us in Netherlands could be an other number in the states .
2 Related Answers
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 28, 2009
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
John Trevino
  • 1420 Answers
  • Posted on Sep 27, 2011
SOURCE: Bosch 11316EVS demolition Hammer soft start not
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
2answers
Armature for kango 950 240
Unfortunately, Kango is gone - there are very few parts available and most of the parts still around will only be found in Europe now. It really is too bad because they were a great hammer.
Feb 22, 2015 • Hammering
Kango 1100 jackhammer gears
A Milwaukee powertool dealer
Sep 26, 2014 • Hammering
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. [email protected]
2helpful
2answers
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
I was hammering for a little less than an hour this morning. The plug got disconnected while the hammer was running. Upon plugging it back in, the hammer will not come back on. I checked the breaker and...
did you have the trigger in the locked position, some tools have a safety that you need to release the trigger after plugging back in to reset the switch. try that first.
1helpful
Kango 900 hammer:\r\nDon't know how to greace the
Milwaukee K900K or the English Kango 900K Blue old or Red some younger handle it differs very much English Kango was using a thick brown grease in 2 chrome colored plastic bags . the Milwaukee K900K has a lubrication grease also not oil but be aware of the operating hours i f you have a K900K model from Brand Milwaukee tools replace also a service kit and the bearings on the armature is important also Its neccesary to protect you from damage
if you have a English Kango its hard and expensive to get a spare parts and most times the tools are worn in the front of the chisel stroke bolds do not get right close and the piston pins are worn it was a good tool about 20 years ago i have serviced much of them . but the first thing thats important that its air-tight in front of the chisel and everywhere thats having a mechanic/pneumatic duty
Milwaukee Services and fill k900k with (IMPORTANT) the right number
6helpful
3answers
Broken on/ off switch for rockworth ARPD1700 hammer drill
rockworth powertask demo hammer needs new trigger how do i get parts
3helpful
2answers
What type of oil i will luricate to my makita HM demolition breaker
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
1helpful
2answers
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
Top Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hammering Expert? Answer questions, earn points and help others
