Question about Alesis MasterLink ML-9600
ML 9600 won't delete audio files
I can get the prompt asking if I want to delete the audio file, but when I hit yes, it will not delete it. What could be impeding the delete?
Write protection? Upper right on display 'U' or 'P'. Move curser there
and toggle with up/yes, down/no.
Posted on Sep 13, 2009
Masterlink ML-9600 schematic
There's a Yahoo user group for this machine, that might be a good place to ask.
Have you asked Alesis directly?
Mar 19, 2013 | Alesis MasterLink ML-9600
W32.trojan.4492
Download SmitfraudFix:
Use this URL to download the latest version (the file contains both English and French versions):
http://siri.geekstogo.com/SmitfraudFix.exe
  • Search:
    • Double-click SmitfraudFix.exe
    • Select 1 and hit Enter to create a report of the infected files. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Clean:
    • Reboot your computer in Safe Mode (before the Windows icon appears, tap the F8 key continually)
    • Select 2 and hit Enter to delete infect files.
    • You will be prompted: Do you want to clean the registry ? answer Y (yes) and hit Enter in order to remove the Desktop background and clean registry keys associated with the infection.
    • The tool will now check if wininet.dll is infected. You may be prompted to replace the infected file (if found): Replace infected file ? answer Y (yes) and hit Enter to restore a clean file.
    • A reboot may be needed to finish the cleaning process. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Optional:
    • To restore Trusted and Restricted site zone, select 3 and hit Enter.
    • You will be prompted: Restore Trusted Zone ? answer Y (yes) and hit Enter to delete trusted zone.
Note:
process.exe is detected by some antivirus programs (AntiVir, Dr.Web, Kaspersky) as a "RiskTool". It is not a virus, but a program used to stop system processes. Antivirus programs cannot distinguish between "good" and "malicious" use of such programs, therefore they may alert the user.
http://www.beyondlogic.org/consulting/proc...processutil.htm
May 02, 2011 | Microsoft Windows XP Professional
You've recorded a track. You hit Stop. You want to capture more of the conversation in the room, so you FORGET to hit New Track, and instead push the record button. Which resets the already-recorded...
Yes, it's gone.
This is the one glaring fault with the 9600, if you select a previously-recorded track, and hit 'record', and then 'play', there's no failsafe, or 'are you sure?' prompt to remind you that there's already content within that track.
If you select the track, and ONLY hit 'record', putting the machine into record standby, but don't hit 'play' to start recording, your previous content is saved when you hit 'stop' - record standby doesn't overwrite anything.
Dec 08, 2010 | Alesis MasterLink ML-9600
How to clear the memory on a Samsung ML-2855ND?
In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Sep 16, 2010 | Samsung ML-2855ND Laser Printer
When deleting files to free up space on the Masterlink's drive, is it necessary to not only delete tracks but also audio files?
Yes, you need to scroll beyond the end of the current playlist, and delete the tracks from the disc, not merely delete it/them from the playlists
Sep 06, 2010 | Alesis MasterLink ML-9600
How can I delete audio songs or pictures from my Sony ereader 600
Hi.
Open the Audio file you wish to delete from the Reader and press the OPTIONS button.
Next, tap the down arrow on the Reader Screen and then, tap the "Delete Audio" option to delete the desired file from the Reader.
The Reader will prompt for YES or NO.
Tap on YES to proceed.
Thanks
Regards mskanji
Feb 27, 2010 | Sony E-reader Portable E-book MP3 Player
I accidentally deleted a recording on the Masterlink ML-9600.
I realise this problem is years old, but for the benefit of anyone with the same problem -
It depends on whether the track has been deleted from a Playlist, or from the Track Storage Area itself. If it's only been deleted from a Playlist, it will still be on the machine
Scroll beyond the end of any playlist, and you'll find the stored tracks. It's only possible to delete a track permanently by going through a 'This will permanently delete the track. Are you SURE?' prompt, so you can't say you weren't warned....
Apr 16, 2009 | Master Heaters Alesis Masterlink ML-9600...
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Jan 15, 2009 | Alesis MasterLink ML-9600
Computer saying could not start because the following file is missing or corrupt the file missing is windows system config system do you no what that means
yes the windows require a file to start that file is either corrupted or got deleted by mistake.so its not getting started .u just try to remove all the wires connected on the motherboard of your cpu and then reinsert it properly.also remove all the cards connected on the mother board and refit it properly.check out if the board it dirty clean it with dry cloth.
or the last option
reinstall the software of which operating system u r using.
Dec 01, 2008 | Computers & Internet
Alesis MasterLink ML-9600 Logo
79 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
