Question about Kenmore 22422 Top Load Washer
Washing machine My washer filled with water and kept filling and filling,,water all over the floor..It wouldn't stop running,,even when i shut the washer off..had to turn the actual water source please
  • 1 more comment
  • neeel Nov 25, 2007
    I fixed the first problem with your help.
    The washing machine would not drain. ( it was the switch on the lid )
    While fixing the switch , I remove a small hose on the level switch and heard air escaping for about 2 seconds.
    I put the hose back on , but now it will overflow .
    Can you help me ?
  • trainwreck33 Feb 18, 2008
    The washing machine will fill up with water, then the spin cycle will start, but the water does not stop filling up the machine. We have to manually turn off the water. The once the water drains, we have to manually turn on the water so the machine will fill back up. Then we have to manually turn the water off once it starts spinning. Otherwise, the water overflows(in both cases). I have replaced the hose, but it did not help.
  • Anonymous Mar 10, 2008
    kenmore washing machine , water ran over, put machine on a different water level and it worked once and ran over again.
Yes it definately needs a new water valve. I had the same problem. VERY easy fix.
Posted on Nov 25, 2007
  • 126 Answers
It needs a new water valve
Posted on Nov 22, 2007
My Kenmore Washer 110.92597200 will not stop filling which causes water to overflow drum onto floor. It does not seem to respond to Water Level setting.
top loader machines have a small tube running up to the sensor that fills with water and affects the level settings
check that it is not a problem with the inlet solenoid not shutting of the water
call a service technician
Nov 27, 2017 | Kenmore Washing Machines
My washer want stop filling up and when I should the machine off the water runs in the floor
Good Afternoon Friend,
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
May 27, 2014 | Frigidaire FWS833A Top Load Washer
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
Jun 17, 2011 | Hotpoint Washing Machines
Water won't shut off
Experienced a similar matter w/ ours that resulted in $3000 worth of floor damage in our house. The solution was an $85 service call for a tech to come out and reconnect a tube that detects when the machine has filled to the proper hight. Without this mechanism in place the washer thought it needed to continue filling (in our case it fille for 2 hours while we were gone). Sorry, never learned the proper name of this water pressure sensor.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
106 people viewed this question
Sal De
 Brian Main
Brian Main
