Question about HP Pavilion dv9260nr Notebook
No display on hp laptop
I bought this hp laptop hp pavilion dv9260nr for $2000 in '07. Everything was fine until yesterday when the screen went blank. Repeated restarting did not work. When i try connecting to an external monitor, I am getting the laptop display fine.
My suspicion is there may be a loose connection between laptop display and mother board.
Not sure how i can confirm and mitigate it?
I have prior experience on desktops hardware troubleshooting but never have played around with laptops.
Appreciate if anyone can help me out (if possible with pictures, not mandatory).
Thanks much.
Murali
    Scholar:
  • 92 Answers
Well, believe it or not. It's good news that it still works with the external monitor. That means it is not the video card which is embedded in the motherboard and is very expensive to fix. Here is a link to disassemble instructions for your motherboard. Scroll down till you see the dv9000's that should be your laptop. Good luck
Posted on Jul 13, 2009
    Novelist:
    Champion:
  • 256 Answers
Due to the problems in the inverter or due to the troubles in the cable connection usually screen flickering happens in the display of HP Laptop.
As the inverters are responsible to supply power to the back-lit of the screen, any problem in the inverter would create troubles.
By replacing your inverter and by checking the connections of the cable in your HP laptop, this problem could be easily resolved.
Get more information to fix HP Laptop No display error . Hope this information helps you.
Posted on Aug 11, 2011
  • 431 Answers
HI Murali I am vortash it sounds as if your laptop screen has lost it's backlight and there fore you dont see anything as it is not lit up another reson may be that your drivers to the screen have been somehow erased , and they need re installing so the screen has shut down try starting the laptop in safe Mode depress F8 on restart and this will go into safe mode and show you if the screen is working .. also check on the screen for any damage .. regards Vortash
I have an HP dv9260nr. Intel Core 2 Duo @ 2Ghz. 2GB Ram and GeForce Go 7600 When I turn it on I see lines on the screen during boot. they are like red green and blu dotted lines. the color is kinda...
Repeat your video cables and look for bent pins. If that don't work reseat your video card unless it's integrated video in which case you would need a new motherboard.
you could also try and revert to an earlier restore point. Press F8 when you restart your system
Oct 20, 2017 | HP Pavilion dv9260nr Notebook
I bought a new hp dv2000 laptop 2 yrs back. till date it was working very fine sudenly yesterday morning when i powered on the laptop thin lines appearing on the screen display... i tried to on the system...
honestly the problem is in your lcd display. it is already defective lcd. replacement of lcd is much expensive. it would be better to buy a new unit rather than replacing the lcd.
Feb 08, 2010 | HP Pavilion dv2000t Notebook
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp dv9260nr 4 beebs, black screen. can i fix or replace video
from what i know about laptops, their VGAs cannot be replaced because they are built into the Mobo so the best solution there is to consult a laptop techinician. He could just reinsert or clean the contacts that could cost cheaply.
Sep 23, 2009 | HP Pavilion dv9260nr Notebook
My HP pavilion dv2713TU laptop does not start, blank screen.
usko land me dal kar chuus fhir randi baja sale banh ke loade,chut age se chut chatio
Mar 14, 2009 | HP Pavilion dv6000z Notebook
Replacement LCD Screen does not work
Hi there
The best way to determine if its the inverter thats burned out is to look very closely at the screen, if you can see a very faint image then its the inverter which has blown or the connection has worked loose.
Post back with the results please.
Good luck
Feb 18, 2009 | HP Pavilion dv5220 Notebook
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
Hp pavilion ze5500 display monitor still doesn't work
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9260nr Notebook Logo
436 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
