Question about Microsoft Xbox 360 Console
Yah when i turn on my 360 nothing comes up but white dots
Nothing comes up but white dots, no red lights, the cords are in fine, i even got new cords and still nothing. it seems to start up normally and i've had it less than a year.
    Problem Solver:
  • 4 Answers
Hey!!! maybe this is goung to sound rude but ... return the xbox immediately ... if they charge you for the shipment pay them ...
I own two xbox and the reason why is because the first one (made in 2007) got the 3 rings of death ... so i fixed it. It worked fine for a couple of months and then it went to hell again, not with the ring of death, but with a "no video but sound" problem. So agan, i fixed it ... now the image is fine, but guess what? ... now it freezes ... this sucks!!! but luckly i have another xbox that i bought a couple of months ago whilst i tried to fix the faulty one ...
I still can't find a permanent solution, but if you want to ruin your MS warranty you can try changing the thermal compund on the GPU and CPU chips, and replacing the X clamps with screws. It works for a little while ...
but then again ... if you have less than a year with your xbox... RETUN IT RIGHT AWAY!!!
hope it helps ...
atte> jabafreak
Posted on Jul 14, 2009
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
How do i connect an x box 360 to a HD ready tv please explain simply
Every xbox comes with the HD av cords. However they are not only the standard red, white, and yellow. But they also come with green, blue, and red av cords. These are the HD cords.Your HD tv should have green, blue, and red outlets on the back of the tv. It also has a another red and white outlet under it. So you have to take the HD cords and plug them into the appropriate outlets and then take the red and white cords from the other set of avs and plug them in right under those cords so you will have sound when you turn your xbox on. On my tv the red and white outlet is right under the HD outlet. But your tv may be different. And make sure that the "box" on the cord that reads either TV or HDTV is flicked toward HDTV.
Aug 27, 2010 | Microsoft Xbox 360 Console
Screen turns black with white dots when i turn on my xbox 360
unplug all cords and reconnect them firmly should fix problem
Aug 05, 2009 | Microsoft Xbox 360 Console
Black screen with white dots moving around everywhere
It is possible to open your Xbox 360 and fix the problem, which isn't recommended, but there are many tutorials, but if it is not 3 red lights then you don't have the Red Ring of Death. If the whole ring around the Xbox 360 is red then this means that either the Audio-Video cable is not connected properly, or the Xbox 360 is not detecting it. You can try cleaning the AV cable or you could try buying a new AV cable. The easiest way to decide on what you should do is go to:
http://support.microsoft.com/default.aspx/kb/906652
That is the specific page for your problem and should give you a solution, and if it does not, then you should be able to contact Microsoft, and if it is still under manufacturer's warranty, then they should be able to fix it for free.
I hope I helped! ~Flascher
Jul 16, 2009 | Microsoft Xbox 360 Console
Black screen white dots
This is likely due to Hardware Failure. Your GPU (Graphics Processing Unit) has likely overheated to the extent of artifacting which is when the device begins to have trouble rendering objects and images and crashes constantly. The only viable solution is to send it in if you still have warranty, Otherwise, you'll have to either buy a new Xbox 360 or send it in for repairs from microsoft.
Hope this helps.
-Gadorach
Jul 13, 2009 | Microsoft Xbox 360 Console
How to fix flashing dots xbox 360?
It could be the cable port needs resetting. On the TV unplug the tv and on the xbox disconnect the cord and turn off the xbox and unplug it. Then put the different cord on and plug the 360 back in.
Jul 09, 2009 | Microsoft Xbox 360 Console
When i play my xbox 360 the screen turns red, i can still see the game and play, and when i access the menu its normal only during actual game time does it show up what should i do?
sounds like the same problem i was haveing i was playing cod waw and i got little white dots all over the screen and i turned it off then back on and i had rrod it could be the a/v cord or its the A.N.E chip if its the chip your screwed cuz its unreplaceible you will need a new xbox if you get 3 red lights you can send it to m.s. good luck!!
Jun 26, 2009 | Microsoft Xbox 360 Console
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
Xbox 360 elite 1 red light
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Colour keeps going and then coming back
i had the same problem till yesterday when i restarted it when it started turning green for no reason and now when i turn it on i can hear the dashboard loading up in the background but my picture is just a black screen with white dots going across. i called microsoft and they said it would cost 100$ to fix mind you i already delt with the red light problem and i got it the day it came out. im just going to go buy a brand new one tommorow i don't even care anymore.
Jul 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
93 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
