Purchased a remote control helicopter and also a simulator but unable to laod this software
  • 1 more comment
  • j4boxers Jul 13, 2009
    Hello
    Get to the end of install ( what i believe is the end and then receive this message D3DRM.dll
    Thanks boxers
    hi
    sorry, i am new at this so please bear with me. i removed the previous attempt to load it and install the program with out the simulator port attached but received the same mess as before d3drm.dll is not loaded. this is for s simulaor for a remote control helicopter
    thanks
    boxers
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash check the specs on the program and what system are you using XP or Vista .. regards Vortash
  • 13,433 Answers
Into the computer? What happens when you try to install it / load it?
Posted on Jul 13, 2009
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
How to synchronize a Hawk talon V3 radio control helicopter with the remote control
If it has 3 channles then you turn the helicopter on first, then turn the remote on. If its not a 3 channle helicopter i dont know sorry.
Jan 04, 2011 | Team International Hawk Talon V3 RC Indoor...
Bought a S108 helicopter. Charged the helicopter and lights are flashing but it looks like the remote control does not work. I have never seen the LED light on. Helicopter has not move an inch yet. I have...
There should be a sticker near the helicopters "on off" switch that has an "A" "B" or "C" on it. Make sure the switch on the controller is set to correspond with that letter. If that isnt it, keep it for parts and buy another. These are VERY delicate toys and most break quite easily.
Dec 27, 2010 | SYMA Toys industrial New Syma S107 Radio...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
I got a remote controll helicopter and when I installed the software for the Flying Model Simulator, it brings up an error saying that D3DRM.DLL IS NOT LOADED.. What can I do to run this program so I can...
The D3DRM.DLL file is the Dynamic Link Library for Direct3D Retained Mode, an older DirectX display technology that was not included with Windows Vista. Direct3D is used to render three dimensional images in applications where performance is important; the most common examples of which are games, CAD drawing programs and graphics editing software.
The error message displayed varies by program, but some some of the more common ones are:
  • "Failed to initialize Direct3D with current settings"
  • "Cannot find the file d3drm.dll"
  • "This application has failed to start because d3drm.dll was not found"
  • "D3DRM.dll is not loaded"
This error is usually a sign that the d3drm.dll file has been deleted, corrupted or altered in such a way that makes it unusable to your program.
To fix errors like this:
1. Install the latest version of Microsoft DirectX. It will fix the d3drm.dll error.
2. Uninstall the game or software program and then reinstall it again.
3. Update the drivers for your video card.
4. If it doesn,t work copy d3drm.dll file to the system folder.
Hope it helps.
Mar 18, 2010 | Microsoft Windows Vista Ultimate Edition
New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
Mar 05, 2009 | Back To Basics Toys R/C Helicopter (27...
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
