Question about Samsung CLX-3160 All-In-One Laser Printer
I have a small peice of paper stuck in the fuser unit of a samsung CLX 3160- How do I remove the fuser to get it out? I removed the 4 screws holding it in, but it is attached somewhere else, is there a trick?
    Champion:
  • 220 Answers
Open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Posted on Jul 15, 2009
  • Larry Lombardo Sep 15, 2013
    Even when I pull the lock to the right, the fuser does not come out. How much force can I use?
How do I fix Samsung Clx-3185 Fuser
The micro "flag" located at the fuser has been broken or dislocated or some gears broken and fuser not spinning.
If you cannot get spares, buy a new printer
May 06, 2014 | Samsung Clx 3185 Multifunction Printer...
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
There is a paper piece ripped and jammed in the Fuser assembley in the back of the Samgsun 3160 fn. How do I change out the Hot fusier. I can pull out the four screw attached to the fuser but there is a...
After you remove the 4 screws, there is a plastic bar on the left side. Grab the end of the bar and slide it inward. That should allow you to pull out the fuser. Hope this helps you.
May 30, 2011 | Samsung CLX 3160fn All-In-One Printer
Paper Jam 1
there is most probly a pease of paper in side the fuser unit.See if you lift the top cover just under the scanner, the hole top lifts up!!!!!!.in the back you wil be able to see the fuser.Be carefull IT IS HOT!!!!!!!see if you can get eny papers in there.And try to take it out carefully.Otherwise will have to strip it to take the fuser apart to clean it up
Jun 03, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My samsung CLX-3160 says "paper jam" and yet there is no paper jam
Open the back door, and inside at the top above the fuser there is a cover that will lift up. In front of the cover will be a spike.
Life the cover, and let the spike (a paper sensor) go into place under the cover and replace the cover and close the door, and it should work.
The spike is lifted as paper passes through.
If you ever lifted the spike while the cover was open and then closed the cover, the spike can't get back so is always lifted and it thinks there is always paper
Mar 11, 2010 | Samsung CLX-3160 All-In-One Laser Printer
How to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Sep 28, 2009 | Samsung CLX-3175FN Printer
Paper is stuck in the top back of the printer and I can't get to it to remove it
by removing the top paper. you got to open up your scanner. on the side there is a latch with a small black cover on the middle. use your finger go to the back of the small cover ans push towards you it shall have came off. remove it and use the press and pull techic your scanner top shall be able to go 90 degrees. there you will be able to see if there is any paper stuck. next open the back door ands flip up the fuser green latch on both end this is to free any paper that got stuck
May 15, 2009 | Samsung CLX-3175FN Printer
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
How do I remove the fuser assembly from my Samsung CLX 3160?
you not able to remove it as i believe it has damaged the roller.send the printer for service.
Mar 08, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
768 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
