Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
My computer shows new hardware found but there's no light on the usb adapter and i can't connect to the internet
  • 57 Answers
Make sure that you have installed the necessary drivers needed for it to work. it usually comes with a CD installer that you can use.
If you're done with the driver installation you may check if the device was properly installed under the device manager.
How to go to Device Manager:
1. right click on My Computer
2. select properties
3. go to hardware tab and click Device Manager
You will see all devices installed on your computers and under the Adapter is where the name of your wireless adapter should be listed if it was properly installed.
Hope this helps...
Posted on Jul 13, 2009
My netbook tells me to reset my wireless adapters Im trying to get wireless internet. It tells me there a network to connect to but it won't let me connet to it.
Hi
For uninstall the driver of Wireless adapters follow the mention below instruction.
  • Go to the control panel and click the Add & Remove program.
  • You see the install driver list you have to select the your wireless adapters and click the remove.
  • After few min you driver is uninstall the window show you driver uninstalling finish.
  • Then reboot you computer.
  • After rebooting you get New hardware found window in start up the notebook,take the wireless driver installation CD and put the notebook CD-ROM.
  • And new hardware found window click next, automatic he install the driver in CD, after complete the driver installation reboot you laptop once more.
  • Now you wireless adapter connect to Internet and your problem will solve.
If my answer solve you problem then give me 4 thum
Thanks
Aug 24, 2011 | Acer Aspire One D255 Netbook
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
My computer will not install the wireless USB software. I need help. I get through the first couple of prompts and then it just looks like it keeps loading but does not.
What is the operating system on your computer. If it is windows XP or VISTA, then try to install the adapter using the found new hardware wizard.
Do not run the disc that comes with the wireless adapter. connect the adapter to the computer first. you will get the message found new hardware.
if you do not get the message that means the adapter is detected by the computer or the software might be installed already. uninstall the software and then connect he adapter.
If you get the found new hard ware message then it will ask you can windows connect ....
select = no not at this time and click next.
on the next window select the option install software automatically and insert the disc that comes with the adapter. it will install the software .
after that you will need to connect to the network.
Click Here for more info
Oct 06, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
NetGear WG111T, hardware not recognized
If the adapter is not detected by your computer, the best way to check if the adapter is bad or not is to tr connecting the adapter to a different USB port and check if the computer will detect it and if still not detected better if you can just connect it to a different USB port and if still not detected on different computer the adapter is already bad...
Aug 25, 2009 | Computers & Internet
USB wireless internet adapter disconnecting
Sounds like the usb ports are sharing an I/O channel. So when you unplug one usb device the CPU is being told that the USB port is not being used.....Maybe..... To test this, hardwire into a data cable and plug in different devices, next unplug a devise and see what happens. If you stay connected you may have found your answer. Unfortunately I don’t think a reimage or restore will fix the problem. If you get the same result try a reimage of your OS. Good luck.
Again sound like a mother board issue.
Questions to ask, When did I notice the problem (Maybe able to restore to the point the problem started.) and did I install new software or hardware when this happened?
Good Luck
Apr 05, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
USB k-595U solitek keyboard, switch to an AT (DIN5) connector
Hi there:
when you installed the keyboard was the computer off and did it show a new hardware found when you turned on the computer it should have and have you tried it on a nothere computer also cause it may be a compatiablity issue here
Feb 16, 2009 | Solidtek ACK-595 Keyboard, Keypad
Linksys wireless adapter not being recognized by 2wire wireless
1. uninstall the WLAN monitor from add/remove programs.
2. restart computer. it should say "found new hardware" (for the WMP54GS)
3. insert the installation CD for the WMP54G, but make sure that you do not install the WLAN monitor. just install the drivers for the card.
Then let windows control the wireless.
Dec 13, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
DWL-122 driver not installing, device not recognized
The wireless adapter will not show on the My Computer. Try to right click the My Computer icon go to properties, then go to Hardware tab then click the device manager button, click the + sign beside the Network Adapters category and check if you have the adapter listed there. If the adapter is listed check if the driver is installed properly by going to the properties of the card.
May 21, 2008 | D-Link Air DWL-122 802.11b Wireless...
2WIRE WIRELESS ADAPTER
or uninstall the broken one from device manager
Jan 16, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
169 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
